PS4 and eCart 5.0.2
Thread begun 11/23/2010 3:18 pm by msjj000 | Last modified 12/06/2010 4:40 pm by Dani Chankhour | 3792 views | 6 replies |
msjj000Beta Tester
PS4 and eCart 5.0.2
Hi WA,
I had a few teething problems when PS3 came out and replaced the code in WA_Store_Cart_PHP and the Definitions file with the rules I wanted.
I tried to do the same in PS4 but that didn't work for me.
I tried using eCart 5.0.2 to created a zero ship value for items under 0.2kg, a value for sub 5kg packages and a value for greater than 5kg. eCart wouldn't modify the WA_Store_Cart and wanted to create a new Cart object. It looks like it takes the values from either the PS3 upgraded store (to PS4) or the current PS3 site.
I've attached the PS3 working store files (ridewerx.com/store), the PS4 store files (ridewerx.com/shop) and the eCart created files.
Can you please provide some guidance in bug fixing this?
Thanks, Mark.
Dani Chankhour
Are you coming across this issue because you have upgraded from PS 3 to 4?
I did a test with PS 4.0.1 and I'm running into this issue.
msjj000Beta Tester
Hi Dani,
I haven't tried a fresh 4.0.1 site as I have been a user since PS1, onto PS2 and then PS3. So yes its on an upgraded test site. I need to localize to my Geo for states, gateway etc hence I always set up a test site in a different directory to ensure a smooth transition.
Hope this helps?
Thanks, Mark.
Dani Chankhour
I have created a support ticket to further assist you with this issue:
msjj000Beta Tester
Thanks Dani
msjj000Beta Tester
Hi Dani, not sure how but I must have closed the ticket by accidient. Can you re-open it please? Thanks, Mark.
Dani Chankhour
I have created a new support ticket.
