Form Toolkit GMC2 Available for WCE
Thread begun 11/23/2010 10:27 am by Anna Robinson | Last modified 11/29/2010 9:56 am by Anna Robinson | 1796 views | 4 replies |
Anna Robinson
Form Toolkit Build GMC2 is available for download.
Serial #: 2UAq6-xiTMF-0yCw0-zAp8L (Please do not install on more than 2 machines.)
All bugs should be fixed in this build; please provide feedback on any testing/experimenting you do with this build. Thank you!
As always, this beta build is only available to the WebAssist Community Experts. Please do not discuss it anywhere but this specific forum. Thank you.
anonymous
Two things.
I am still getting the error now in Form Builder that states:
The WAFV_ShowIf script does not define the findServerBehaviors.
This occurs while inserting a form.
I also noticed that when installing or editing a captcha, when you check that you want a refresh image available and then later go back to edit the captcha, the dialog box does not show the check. So if you check it back again, it actually creates a second refresh. While this is minor, I think it was probably intended that the box would remain checked to indicate that the feature is activated.
Best regards,
Brian
Anna Robinson
We're looking into the Form Builder issue right away. Thank you for reporting both. Are you using Form Builder 2?
anonymous
Hi Anna,
Yes, it occurs on Form Builder 2 when I try to insert a new form or edit and save an existing form. It occurs during the stage when the extension processes the form.
Best regards,
Brian
Anna Robinson
Hi Brian, Looks like the fix was made for compatibility with Form Builder 1, but it was still an issue in Form Builder 2. We fixed it and the extension is now available for purchase. Thank you very much for reporting it!
