Shipping Same as Billing CHECKMARK?
Thread begun 6/17/2009 6:09 pm by Peterson Design Studio - jefferis | Last modified 6/18/2009 2:07 pm by Peterson Design Studio - jefferis | 6417 views | 6 replies |
Hi Folks,
I have set up an ecart, and although the default checkout page is created with the option to check "Shipping the same as billing," when you check it off, the shipping is not filled out.
First of all, is that the normal and expected behavior?
Second, does eCart then auto fill in the shipping into the Order details and the checkout pages with the billing address? I notice in my Database that some of the fields are empty...
Jeff
Yes it should. Most likely the form element names are wrong somehow. That would explain the checkbox not working as well as the values not appearing in the database.
The Check box works, it just does not auto fill the shipping fields...
<input type="checkbox" name="eC_SameAs" id="eC_SameAs" value="1" onclick="eCart_copyBillingToShipping(this);">
Here's a sample of the first field for first name in shipping:
<input type="text" name="shipping_firstname" id="shipping_firstname" value="">
as opposed to the billing field:
<input type="text" name="firstname" id="firstname" value="">
That looks correct. And the firstname field is one of the ones that doesn't work? Do you have a url where I can view the code? That might allow me to spot the problem.
You may have to go through a few steps to see the page:
checkout.php
Click Jewelry Selections and any submenu except Overview. Add the item to a cart and then click VIEW CART, and click CHECKOUT and it will take you to this page. An empty cart will not work. I just found an error on the checkout buttons on the main catalog pages... it isn't working. But that is not the problem
Looks like you are missing the script reference:
<script src="WA_eCart/Scripts/copyShipping.js" type="text/javascript"></script>
should be in the header
THANKS RAY,
I don't think I deleted it, I guess it was not auto created by the Cart setup...
Jeff
