Editing PS4 store message
Thread begun 11/22/2010 3:47 pm by spdraper347403 | Last modified 11/29/2010 6:54 am by Jason Byrnes | 2302 views | 3 replies |
spdraper347403
In PS3 you could edit the store message background/image/size by editing home.css but it would appear that the home.css file doesn't exist anymore for the home page.
Is there any way to edit the store message area now?
It would seem that a lot of the customisation facility has been reduced in PS4, unless it's all hidden away somewhere. Using the style editor only allows for colour, fonts and pictures which is not nearly enough.
you can still edit the css directly if you wish, though which css file to edit depends on the design theme you are using.
for example, if you are using the default design theme, the css file is at:
webassist/themes/default/css/default_home.css
spdraper347403
Jason,
Thanks for that. One thing though is that webassist/themes etc resides in the install folder. Aren't we advised to delete this folder after installing?
Sid
after you have run the install, another webassist folder will be created at the root.
