Login out users
Thread begun 11/22/2010 12:04 pm by romeo370381 | Last modified 11/29/2010 9:52 am by Jason Byrnes | 3256 views | 3 replies |
romeo370381
Logging out users
I used security assist to define my rules and now trying to logout users using simple php logout script, but doesn't work, any one with solution out there?
can you send a copy of your page and the logout script?
info383352
I've the same problem....I've generated the LogOut page form the Security Assist wizard, but without a script in the page how should it work?
This is the generated page:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
"http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
<title>Log Out</title>
<link href="../WA_SecurityAssist/styles/Refined_Pacifica.css" rel="stylesheet" type="text/css" />
<link href="../WA_SecurityAssist/styles/Arial.css" rel="stylesheet" type="text/css" />
</head>
<body>
<div id="LogOutContainer" class="WAATK">
<h1>Log Out</h1>
You have successfully logged out. </div>
</body>
</html>
No scripts, css only....
the security assist logout page uses the Clear Session Value behavior from Cookies toolkit, if cookies toolkit is not installed, the clear session value code may not be added to the page.
add the following at line 1 of the logout page:
if (!isset($_SESSION)) {
session_start();
?><?php
if ("" == ""){
// WA_ClearSession
$clearAll = TRUE;
$clearThese = explode(",","");
    if(
$clearAll){
        foreach (
$_SESSION as $key => $value){
            unset(
$_SESSION[$key]);
    else{
        foreach(
$clearThese as $value){
            unset(
$_SESSION[$value]);
