Logo - can not change - Errors
Thread begun 11/22/2010 9:58 am by Larry321390 | Last modified 12/01/2010 12:56 pm by Jason Byrnes | 2246 views | 3 replies |
Larry321390
I'm trying to change the Logo in admin. The logo broswe button bring up a screen saying "loading" and when it say 100% there is nothing there. I'm running IE 8 but have tried in firefox and get the same behavior.
The little yellow icon in the lower left corner, when clicked and expanded shows the following:
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C)
Timestamp: Mon, 22 Nov 2010 17:44:39 UTC
Message: 'jQuery' is undefined
Line: 44
Char: 1
Code: 0
URI: all.php
Line: 23
Char: 13
Code: 0
URI: index.php?subfolder=logos
Message: 'kfm_vars.root_folder_name' is null or not an object
Line: 5
Char: 2
Code: 0
URI: all.php
Message: 'kfm' is null or not an object
Line: 14
Char: 1
Code: 0
URI: en.js
Message: 'kfm_widgets' is null or not an object
Line: 68
Char: 17
Code: 0
Message: 'kfm_vars.permissions' is null or not an object
Line: 26
Char: 1
Code: 0
URI: widget.js
Message: 'kfm.lang' is null or not an object
Line: 3
Char: 2
Code: 0
URI: plugin.js
Line: 31
Char: 2
Code: 0
URI: hooks.js
Line: 3
Char: 2
Code: 0
URI: plugin.js
Line: 10
Char: 1
Code: 0
URI: plugin.js
Line: 31
Char: 2
Code: 0
URI: hooks.js
Line: 12
Char: 1
Code: 0
URI: plugin.js
Line: 46
Char: 1
Code: 0
URI: plugin.js
Line: 31
Char: 2
Code: 0
URI: hooks.js
Line: 31
Char: 1
Code: 0
URI: plugin.js
Thanks for your help
Larry
ADDITIONAL INFO
When saving the theme the colors and fonts do not save. they go back to the defaults. Although a do get a new theme.
Larry
try replacing the webassist/themes/default folder with a fresh copy from the power store download.
Larry321390
500 error
I started over. deletted everything including the database. I loaded the zipped file to the sever and unzipped it in the server. ran the i installation and all works except design -- saving a theme. the new theme is ther but I'm getting the following error and no details are saved:
500 Internal Server Error
The request was not completed. The server met an unexpected condition.
174.122.114.250/~rmi25/PowerStore%20Files/webassist/plugins/styler/unload.php (port 80)
I tried setting all the permision along the path to 777 but that did not fix it.
Hope you had a nice Thankgiving.
Larry
MORE INFO
I found the error reporting code in another post and added it to unload.php .
error_reporting(E_ALL);
Ran thru the save theme in ie8, latest firefox and latest chrome. All gave me the same error with no additional info.
Regards,
Larry
