Dataasist 2 error help please!!
Thread begun 11/22/2010 8:06 am by info273952 | Last modified 11/29/2010 6:47 am by Jason Byrnes | 4644 views | 7 replies |
info273952
Hello, I am new to the forum but I know and use WebAssist extensions.
But I have a serious problem:
I recently upgraded to DATAASSIST2 which I think is fantastic!
quersto error but I can not remove:
Creating a Wizard with the database DataAssist example provided I get this is to upload the data entry
Error Microsoft VBScript runtime error '800a0009 '
Index out of range: '[number: 1]'
/ WA_DataAssist / WA_AppBuilder_VB.asp, line 206
help please!
can you send a copy of your pages in a zip archive so i can examine the code to see what the problem is.
info273952
Dataassist Error
Thank you here is the test project in fire rar.
The data type is not getting set correctly.
on the update page, double click the update record server behavior and make sure each column has the correct data type set, you will also need to do this on the insert and delete pages.
info273952
Dataassist
Traduzione da Italiano verso Inglese
I checked it is correct,
but I doubt a wizard when I have to include ID in the table insert and update.
while the delete function works correctly.
could be a server problem?
I also tried on a new database with one table, the effect is the same!
thanks
here is a screen shoot showing the problem, the data type for the columns is set to undefined, you need to change this to text.
info273952
OK
grzie many.'ve been very kind!
you're welcome.
