CMS Install Error
Thread begun 11/21/2010 9:00 am by npizzola365988 | Last modified 11/21/2010 11:23 am by npizzola365988 | 1601 views | 2 replies |
npizzola365988
CMS Install Error
Hello... when I do an install of the CMS I am able to get to the serial number page of the install wizard and then I get the following error:
Fatal error: Call to undefined function curl_init() in /var/www/clients/client0/web10/web/cms/install_cms/serial.php on line 20
can anyone help me get past this?
neilo
It may be that cURL is not enabled on your remote server's php setup.
To find out, create an empty file and enter the following in code view:
phpinfo ();
Save the file as phpinfo.php and upload it to the root directory of your remote server. Navigate to the file in your browser, and it will bring up your server's php configuration.
You should see a section called curl.
If it is not there, you will need to ask your hosting providers to enable curl in the php.ini file.
npizzola365988
BINGO! I'll contact my ISP and have it changed... thank you so much!
