user 99 permissions
Thread begun 11/19/2010 9:35 pm by Russell Collins | Last modified 2/16/2011 10:55 am by Jason Byrnes | 3989 views | 6 replies |
Russell CollinsBeta Tester
user 99 permissions
Is there any way to stop PS4 creating user 99 permissions on the webassist directory and sub folders when creating a new PS.
Every time I have to get the hosting support people to change them to the actual user.
Regards
Russ
I'm not sure what "user 99" permissions is, but you could create a script to run to edit the permission level after the install is completed:
use the following code to change the permissions on the webassist directory to 755, this will allow read, write execute for the owner and read, write for the user and group:
chmod
("webassist/", 0755);
Hi Jason,
My hosting support said user 99 is "nobody"
and to change it to the owner only they can do it.
It seems to create this every time a theme is created.
Maybe I should give it the same name as the original theme name.
The hosting provider said that CMS systems often do this.
Russ
west
I have the same issue. Can't make changes to a user 99 file.
Is there a way to stop this from happening?
did you try this code:
chmod
if that does not work, you will need to contact the host about this, it is a server setting causing the issue.
west
Where/how do I run that script?
try adding that code at line 1 of the webassist/themes/theme_open.php file.
