Powerstore 4 gallery problems
Thread begun 11/19/2010 5:28 pm by davkim_00418069 | Last modified 11/23/2010 7:12 am by Jason Byrnes | 4686 views | 9 replies |
davkim_00418069
Hello!
I have the powerstore 4, with the picture gallery. When I put the picture gallery in one of my pages in my secured website, the gallery comes out blank, but when I unsecure the website, the gallery is fine, meaning that I can see the pictures in the gallery. What is the problem with the site?
Please let me know,
thanks,
David
when a page displays blank, it means a php error is occurring but error reporting is turned. To fix the issue, we will need to know the error.
Add the following code at line 1 of the page that displays blank"
error_reporting
(E_ALL);
ini_set('display_errors','all');
Once we know the error, we can fix the issue.
davkim_00418069
Hello Jason,
I do not know where to put to codes in the php; however, I found out that the address of the gallery images are Neutral20Champagne01_62c.jpg. My site is secure, thus, when I tried to open in a new window, it said: Bad Request
Your browser sent a request that this server could not understand.
Reason: You're speaking plain HTTP to an SSL-enabled server port.
Instead use the HTTPS scheme to access this URL, please.
Hint: www.shopmytrend.com/
On my htaccess, i have put:
RewriteEngine On
RewriteCond %{SERVER_PORT} 80
RewriteRule ^(.*)$ https://www.shopmytrend.com/$1 [R,L]
Can you please tell me how the gallery image address can be changed from http to https?
thank you,
David
in the webassist/globals/global.php file, try changing:
$WAGLOBAL_Root_URL = ((isset($_SERVER['SERVER_PROTOCOL']) && strpos($_SERVER['SERVER_PROTOCOL'], 'HTTPS') !== false) ? 'https://' : 'http://') . $_SERVER['SERVER_NAME'] . ( (isset($_SERVER['SERVER_PORT'])&& $_SERVER['SERVER_PORT'] != 80)?":".$_SERVER['SERVER_PORT']:"") . $assumedRoot;
$WAGLOBAL_Root_URL = 'https://' . $_SERVER['SERVER_NAME'] . $assumedRoot;
davkim_00418069
Hello Jason,
I did change it in the file as you have directed, but still, the gallery images are not showing up nor the address changed from blah.com:443 to https...
try making the same change in the galleries/global.php file.
davkim_00418069
I did, and still does not work....
That line of code is also in the mediarss.php file, change it there as well.
davkim_00418069
It worked! Thanks a lot Jason!
you're welcome.
