Radio groups validation error.
Thread begun 11/19/2010 8:26 am by FrankJay | Last modified 11/23/2010 5:09 pm by Jason Byrnes | 3231 views | 5 replies |
FrankJay
I have manually created and styled a form that has three radio groups and some text input boxes. I then apply client validations to the radio groups. When testing and making selections, the radio group validations prevents the form from being submitted. The validation for the radio groups is set to required: and if error occurs: continue validation.
A duplicate form without client validations works perfectly and inserts the form records to the database.
Similar threads refer to support tickets being created with no solution thereafter. Please advise.
find the following line:
if (formElement.length && inputType.toLowerCase()!="radio" && inputType.toLowerCase()!="select") formElement=formElement[0];
and change it to:
if (formElement.length && inputType.toLowerCase()!="radiogroup" && inputType.toLowerCase()!="select") formElement=formElement[0];
I am logging this as a bug to corrected in a future version.
FrankJay
Don't see code change
Thanks Jason,
I don't see the change. Both lines of code are the same. Appreciate logging the bug.
the second line should have "radio" changed to "radiogroup"
FrankJay
Fixed Validation
Thanks Jason
Changed the code as directed. Radiogroup validation working correctly. Appreciated.
you're welcome.
