International orders returning 0 for UPS shipping
Thread begun 11/19/2010 8:07 am by tricomb2b | Last modified 12/02/2010 1:26 pm by Jason Byrnes | 2983 views | 3 replies |
tricomb2b
I'm working on a project where ecart was used and while there are very few international orders the ones we do get are showing up with 0's for shipping. Using the failure URL I'm getting an error from UPS of "Message: The requested service is unavailable between the selected locations." Looking at the database it appears that international shipping has always returned 0's.
The city, state, postal code I'm testing sending to is Magog, QC, CA J1X 2N1.
This is an example from one of the orders that received a 0.
that error means the Shipping type you selected will work for an international order.
on the confirm page, lok for the following line:
$Shipping_Parameters["CarrierCode"] = "03";
(The value may be different)
We can dynamically set this besaed on the shipping country:
$Shipping_Parameters["CarrierCode"] = (isset($_SESSION['eCartCheckoutForm_shipping_country']) && $_SESSION['eCartCheckoutForm_shipping_country'] == "US")?"03":"07";
This will use ground shipping (03) if the shipping country is US and Worldwide Express (07) if not
Here is a listing of the possible values.
- 2nd Day Air = 02
- Ground = 03
- Worldwide Express = 07
- Worldwide Expedited = 08
- Standard = 11
- 3 Day Select = 12
- Next Day Air Saver = 13
- Next Day Air Early AM = 14
- Worldwide Express Plus = 54
- 2nd Day Air AM = 59
- Express Saver = 65
tricomb2b
Is it possible this code is only in newer versions? I'm not able to find anything similar to the code below (realizing that this uses ASP.VBscript version not PHP, I still couldn't find anything similar to this code). Is there a way to see what version was used to build the cart? I'm thinking this was done with an earlier version.
For the shipping there were the options of:
Next Day Air
2nd Day Air
Ground
Worldwide Express
Worldwide Expedited
Standard
3 Day Select
Next Day Air Saver
2nd Day Air AM
Express Saver
All of these returned 0's for international shipping.
yeah, it sounds like you are using ecart 4.
