Need help
Thread begun 11/18/2010 2:34 pm by Roxana | Last modified 11/19/2010 1:34 pm by Jason Byrnes | 3878 views | 8 replies |
Roxana
Need help
Not really an ecart question, but I am stuck :(
When I make a change to the php code, the browser displays a blank page. Problem is, the php code is too long to trouble shoot.
There is a little piece of php code, that - when added to the top of the code - will display what's wrong. I forgot how and can't find it. Could someone help me out?
neilo
Hi Roxana,
error_reporting
(E_ALL);
Roxana
Thank you so much. I will try to trouble shoot now.
Roxana
The browser now faithfully shows me, what the problem is. Still too complicated :)
I am giving up for now.
What is the error in the browser, perhaps we can help troubleshoot it.
Roxana
Hi Jason. I tried to pin-point yesterday's problem, and I ended up solving it :)
Then I ran into the next problem. This may be a question of "it just doesn't work".
My site is multi-lingual. On the email page is a top image, that changes with the selection of the language. The choice is made on the form page. If we were to write an email to an English customer, we would hit the English button, image changes, and then the image on the email page is English as well. This language choice is done with include files, where the file is a php page with just the image.
It works for the email page in the browser, but on the email itself the image is missing.
This is the php code for the image is
<?php include ('includes/'.$folder.'/headerFloat.php');?>
The source code on the headerFloat.php is
<img src="http://www.name.com/images/header/german1.png" width="777" height="60" alt="name" />
Could it be, that this construction simply does not work? I tried to put just the image in the include folder, but that did not work at all. The entire is messed up (random letters and symbols).
my first guess would be a pathing issue.
the file that contains the email message is not in the same place as the file you applied UE to, so the include path will need to be adjusted.
Roxana
Not a path issue.
Apparently the image in the include file has to be in a div tag, and that div tag has to have an id (can be random).
Now it works. Two days work for a mere image swap, but I am relieved nonetheless.
ok, glad to hear it is working.
