Uploading .pdf
Thread begun 11/18/2010 12:50 pm by Remco209061 | Last modified 11/18/2010 1:33 pm by Jason Byrnes | 2047 views | 1 replies |
Remco209061
Uploading .pdf
Hello,
is it possible to restrict the upload file's to one extension? for example a .pdf instead of a .txt? I see in the helper.php the possibility to restrict the images extension.
grts Remco
you can do this using the Server validations.
Select File extension validation, click the lightning bolt next to server variable and select the File field extension variable from the form binding group. When you add the file extensin validation, you will be prompted for extensions you wish to allow.
