Map Not Rendering / Appearing in Browser
Thread begun 11/18/2010 11:42 am by ew391940 | Last modified 11/18/2010 1:18 pm by Jason Byrnes | 3121 views | 5 replies |
ew391940
I have a website and i can't get the map to appear. The map works on one page which is in the root folder. I have another map on another page located in a subfolder. When i added the map to the page located in the sub folder it created new google maps folders inside the sub folder. I uploaded all this to the site and it still doesn't work. No map is showing up. The place holder shows while im working on the page but when i view it in the website it gives me a blank page.
80207.html Not working
Residential.html works fine on this page.
What is the issue??? Thanks for your help.
the issue is the last script tag that intializes the map:
<script type="text/javascript" src="google_javascript/wagmp_maps.js"></script>
needs to point down one directory:
<script type="text/javascript" src="../google_javascript/wagmp_maps.js"></script>
ew391940
Thank you so much!!
Works perfectly, I knew it had to do something with the links but i couldn't figure it out. Thank you so much.
you're welcome.
ew391940
Ooops Still Not Working Right
Ok now im getting the map (part of it) to pull up. When i open the page now the map pulls up but its like frozen like half of the map is showing and it is all the way shifted to the left???
On the
Residential.html
it is still working just fine but on the second page where you had me change the code directory it is not working correctly. The map pulls up but then only like half the map shows with the rest a solid gray (as if it is frozen) and the push pins and pop up is pushed all the way to the left (like the map isn't centering)
Example:
80207.html not working as described above.
What do I do now that the map appears but doesn't work correctly?
see this post for details on the fix for this issue:
showpost.php?p=56470&postcount=4
