Creating a Checkout Page
Thread begun 6/17/2009 12:51 pm by glozinski107205 | Last modified 6/18/2009 7:55 am by Ray Borduin | 3677 views | 3 replies |
glozinski107205
I am creating a checkout form. I have used spry validations on this form. However, I also want to use a recordset. Can I do both effectively? or is there another way to bring in the customer information from the customer registration page that would have it entered automatically. Perhaps cookies? Thank you in advance.
The recordset is the correct way. You should be able to add recordset references as form values or in place of spry arguments by dragging them from the bindings panel. I don't think spry will interfere with doing it the same way you would without spry.
glozinski107205
Okay I am trying to get there but I go from UsersLogin to Users Profile. How do I change so that I get to start shopping so that I can get to check out form? If we change the direction of the Users Profile where should it then be placed and redirected if customer wants to change profile information. Confused! Big Thanks!
You can change the page that you go to after the login by updating the user authentication server behaviors on the login page.
You can then add a link somewhere else in your site to the update profile page. A simple link to the user update page will work anywhere you want to place it.
