Remove item not working
Thread begun 6/17/2009 9:35 am by ijs174940 | Last modified 6/17/2009 10:10 am by ijs174940 | 1673 views | 1 replies |
ijs174940Beta Tester
Using ecart 4.50 on cs4 in php.
When i select eh remove tick box and select update the page just refreshes but the itme still stays in the cart, if I us the clear cart button all items are removed correctly, can you give me info on what action is performed when selecting the remove box.
The only other alternative i have is to remove the ecart alltogether and re add it, but I have a lot of custom rules that i dont want to go thru again.
Fixed!
I had simply left out setting the item ID to the add to cart ID, no wonder it could not remove it! it had no ID telling it which one to remove.
I need a new job!
