Captcha images do not show up on contact form
Thread begun 11/17/2010 11:46 am by vvrao007350432 | Last modified 11/23/2010 1:22 pm by Jason Byrnes | 7527 views | 11 replies |
vvrao007350432
on local testing server every thing is ok. on godaddy linux sharing hosting server captch image does not show up on contact form and the image link info is greyed out.. i need this to be addressed as soon as possible...
can you post a link where i can see the issue please.
vvrao007350432
captcha problem link
am using power store 3.01
here is the link
contactus.php
browasing directly to the page that is supposed to generate the captcha image:
MODERNA_.TTF
it loos like an issue with the free GoDaddy account. Where they are forcing the banner on the top of the page, they are overiding the header call to create the capthaca png image.
you can try renaming:
WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php
WA_ValidationToolkit/WAVT_CaptchaSecurityImages.png
then change the captcha image source:
<div class="text"><img  src="WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php?noisecolor=<?php echo $WAGLOBAL_Captcha_Noise?>&bgcolor=<?php echo $WAGLOBAL_Captcha_BG?>&textcolor=<?php echo $WAGLOBAL_Captcha_Text?>&transparent=<?php echo $WAGLOBAL_Captcha_BG_transparent?>&characters=<?php echo $WAGLOBAL_Captcha_Characters?>&width=<?php echo $WAGLOBAL_Captcha_Width?>&height=<?php echo $WAGLOBAL_Captcha_Height?>&font=<?php echo $WAGLOBAL_Captcha_Font?>" alt="security code" /></div>
to;
<div class="text"><img  src="WA_ValidationToolkit/WAVT_CaptchaSecurityImages.png?noisecolor=<?php echo $WAGLOBAL_Captcha_Noise?>&bgcolor=<?php echo $WAGLOBAL_Captcha_BG?>&textcolor=<?php echo $WAGLOBAL_Captcha_Text?>&transparent=<?php echo $WAGLOBAL_Captcha_BG_transparent?>&characters=<?php echo $WAGLOBAL_Captcha_Characters?>&width=<?php echo $WAGLOBAL_Captcha_Width?>&height=<?php echo $WAGLOBAL_Captcha_Height?>&font=<?php echo $WAGLOBAL_Captcha_Font?>" alt="security code" /></div>
vvrao007350432
which file has this code?
sorry , i could not find which php file has this div tag. can you please give me a clue where to replace? i appreciate
the contact page:
contactus.php
vvrao007350432
still cptcha images do not show up...
yes i renamed to png extension and replaces the div tag. now the link for images is not grayed out. but i can not see the images... could be problem if we plan to have banner ad in general.. so like to address this issue
well, now if I browse directly to the image file:
MODERNA_.TTF
it shows an error "The image cannot be displayed because it contains errors".
The heart of the issue is that your free go dadddy hosting account is forcing banner adds on your php pages, this is causing the captcha php page "WAVT_CaptchaSecurityImages.png" not to generate the image correctly. I thought we could work around the issue by changing the extension, but apparently not.
It would seam the GoDaddy free Hosting plan will not work with captcha.
vvrao007350432
i see the problem...
is there any way i can avoid captch image generation and security code itself.. which lines to be removed. we are okay with SECURITY QUESTION., WE DO NOT NEED CAPTCHA QUESTION IN FACT.. what lines to remark to gracefully solve this problem?
to remove the captcha and security question, remove the following code blocks:
line 433 - 434:
var sprytextfield3 = new Spry.Widget.ValidationTextField("sprytextfield3", "none", {validateOn:["blur"], minChars:5, maxChars:5});
var sprytextfield4 = new Spry.Widget.ValidationTextField("sprytextfield4", "none", {validateOn:["blur"]});
line 268 - 409:
<p>
            </p>
            <p>
                <label for="Security_code">Security Code:</label>
                        <span id="sprytextfield3">
                            <input name="Security_code" type="text" class="inputValue" id="Security_code" onblur="if (document.getElementById('captchaServerError')) document.getElementById('captchaServerError').style.display='none'" maxlength="40" />
                            <span class="textfieldRequiredMsg">A value is required.</span>
                <span class="textfieldMinCharsMsg">Minimum number of characters not met.</span>
                <span class="textfieldMaxCharsMsg">Exceeded maximum number of characters.</span>
              </span>
if (ValidatedField("contact","contact"))  {
                                if ((
strpos((",".ValidatedField("contact","contact").","), "," "4" ",") !== false || "4" == ""))  {
                                    if (!(
false))  {
                                    <span id="captchaServerError" class="textfieldServerError">Your security code entry did not match the image.</span>
                                    <?php //WAFV_Conditional contact.php contact(4:)
            </p>
            <p>
               <div class="text"><?php require_once("WA_ValidationToolkit/WAVT_CaptchaSecurityQuestion.php"); ?></div>
            </p>
            <p>
                <label for="Security_question">Security Question:</label>
                 <span id="sprytextfield4">
                            <input name="Security_question" type="text" class="inputValue" id="Security_question" onblur="if (document.getElementById('securityServerError')) document.getElementById('securityServerError').style.display='none'" maxlength="40" />
              </span>
                                if ((
strpos((",".ValidatedField("contact","contact").","), "," "5" ",") !== false || "5" == ""))  {
                                    if (!(
false))  {
                                    <span id="securityServerError" class="textfieldServerError">Your answer was not correct.</span>
            </p>
line 27- 28:
$WAFV_Errors .= WAValidateLE(((isset($_POST["Security_code"]))?strtolower($_POST["Security_code"]):"") . "",((isset($_SESSION["captcha_1"]))?strtolower($_SESSION["captcha_1"]):"") . "",true,4);
  $WAFV_Errors .= WAValidateLE(((isset($_POST["Security_code"]))?strtolower($_POST["Security_question"]):"") . "",((isset($_SESSION["random_answer"]))?$_SESSION["random_answer"]:"") . "",true,5);
