Problems with initial install
Thread begun 11/17/2010 7:02 am by cnmpat323745 | Last modified 11/18/2010 11:36 am by Jason Byrnes | 4175 views | 16 replies |
cnmpat323745
I installed a MySQL 4 database, and then uploaded the files per directions.
When I went to this page, index.php
this is the link that appeared, with a totally blank page.
users_login.php
The PDF that deals with problems with installation was not available, and I don't know what to do next. Please advise.
I have written tech support but so far haven't received and answer, so I am exploring the forum.
Pat Sonnenstuhl
Webmaster and Communications Liaison
Worship Ministry chair elect 2011
webmaster@theunitedchurches.org
The United Churches
www.theunitedchurches.org/
it's rather curious that it is redirecting to the admin_cms/users_login.php folder,the PowerCMS Package does not contain an admin CMS folder. it contains an admin folder.
Did you rename the admin folder to admin_cms?
where there any other folders that you renamed?
You should not be renaming any of the folders or files, this will break the links.
It doesn't look like all of the files where uploaded to your site.
if you uploaded the power cms files to:
TUCOinfo/
there should be an install folder at:
install
going to:
1.php
gives me a 404 page not found error.
cnmpat323745
Installation issues
No, I didn't rename anything. I created an TUCOinfo folder and uploaded all of the downloaded files to that folder. I see the index.php file there, but didn't change any of the other files.
Should I set up admin privileges with the database, and then make these the same as what I need to do with the installation wizard ?
What do you recommend I do ?
also, this link doesn't seem to go to the appropriate pdf:
common_installation_issues.pdf%22
this is the message I get:
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<Error>
<Code>NoSuchKey</Code>
<Message>The specified key does not exist.</Message>
<Key>technotes/common_installation_issues.pdf"</Key>
<RequestId>E7A0443F20F27919</RequestId>
&#8722;
<HostId>
V6JKwZIt5NUzuKT9Hn32buqkOS1MutLekA9PKgIEtaIRSLv1vp+M3WFr3Fa6VeZ8
</HostId>
</Error>
cnmpat323745
Problems with installation
I tried to submit a screen shot, but can't, of the files in the folder.
suggestions ??
Pat
OK, I see, the admin folder was renamed to admin_cms in the latest update. sorry for the confusion.
where the login page is showing blank, it indicates that a php error is occurring but error reporting is turned off.
add the code at line 1 to turn error reporting on:
error_reporting
(E_ALL);
the cause of the error will likely point us to why the install is not starting.
cnmpat323745
Installation issues
I do not understand where to add this code.
please be more specific.
I am new at this.
add the code at line 1 of the admin_cms/users_login.php file
cnmpat323745
Installation issues
do you mean the logininfo.php file ?
there isn't one by the name that you gave.
Pat
your initial report says you try to access the index page:
index.php
and are redirected to the users login page:
users_login.php
it is this users_login.php page that i need you to add that code to.
cnmpat323745
Installation issues
This is the message I get. I added what you suggested to the user_login.php file in the admin_cms file and uploaded it to replace the other file. This is the message I got when I looked for the index.php file. Now what ?
Warning: main(../WA_CMS/library.php) [function.main]: failed to open stream: No such file or directory in C:\Domains\theunitedchurches.org\wwwroot\TUCOinfo\WA_Globals\WA_Globals.php on line 4
Fatal error: main() [function.require]: Failed opening required '../WA_CMS/library.php' (include_path='.;C:\PHP4\includes') in C:\Domains\theunitedchurches.org\wwwroot\TUCOinfo\WA_Globals\WA_Globals.php on line 4
