Can't edit Css design for checkbox
Thread begun 11/17/2010 1:30 am by Rune Brynestad | Last modified 5/12/2011 12:41 pm by Jason Byrnes | 2397 views | 8 replies |
Rune Brynestad
When I try to edit the css design for checkbox I get the error message attached.
Steps to reproduce:
In the add form window, click the "Customize CSS" button.
Choose "Form elements" from the dropdown menu
Choose "Checkbox" from the second dropdown menu, and I get the Javascript error message attached.
Edit css design works for any other form element, but not for checkbox.
I have deleted the winfile cache.
Regards
Rune
in the Configuration/Commands/WAFB_EditTheme.js file, change line 815:
if (!elmSize.options.length) {
if (!elmSize) return;
Rune Brynestad
Works perfect!
Regards
Rune
Great, glad to hear it is working.
jamie424562
same problem, made change now a new one....
Hi There
also had above problem with the css form builder, check box's.
I made the above change and now have a new error msg:
file "WAFB_EditTheme": initializeUI is not defined.
going back to original file but will still have same problem (at least i can edit most of the form, just no check boxes).
Any ideas for a solution?
Thanks in advance
jamie424562
achhhh
Changed back to original js and still have the same error after making the changes, cant edit anything now for the forms.
help.....
make the change in the js file, then delete the cache file from the users configuration folder:
jamie424562
great working again, guess that .Dat file the weassist bain, so noted thanks.
