ToolKit Beta - Captcha
Thread begun 11/16/2010 2:36 pm by tom92909 | Last modified 11/18/2010 8:30 pm by tom92909 | 3871 views | 9 replies |
tom92909Beta Tester
The Captcha tool is simple and straight forward regarding it initial configuration. However upon completion, I then attempted to utilize the Validation show if tool (I have FormBuilder 1 installed) and I'm getting the following series of errors....
Anna Robinson
Thanks Tom. QA is following your threads and will let you know if they have any questions.
Matthew Meling
Hey Tom,
I looked into the situation, and it seems that Form Builder 1 and Form Toolkit were having some file incompatibilities. We're fixing the issue right now, and you won't see it again in the next build.
Thanks for letting us know about the bug.
tom92909Beta Tester
I purchased FormBuilder 2, installed it, realized that I really only wanted to use it in specific situations, so I reverted back to FormBuilder 1.0.2....just for full disclosure.
Matthew Meling
Hey Tom,
I heard back from an engineer, and the issue is actually with Form Builder. The bug has been logged for Form Builder, but unfortunately, there is no fix within Form Toolkit we can do.
tom92909Beta Tester
I also just thought of another possible contributor...
Contact Form Solution Pack 1.0.3
tom92909Beta Tester
Ok. I've removed FormBuilder completely. I reinstalled the toolkit. It seems to be working now.
The validation in general seems pretty much the same, but specifically how do I validate the Captcha graphic and what the
html:
<input id="Security_Code_1" name="Security_Code_1" type="text" value="" />
has in it?
tom92909Beta Tester
Is it...
Like Entry? $_SESSION['captcha_Security_Code_1']
Yes, like entry validation using the form element and the captcha session variable... both should be listed in the bindings.
tom92909Beta Tester
Working with build v003 for Captcha validation. It' works GREAT!
