WA_SHA1Encryption Decrypt?
Thread begun 11/16/2010 12:12 pm by tn228553 | Last modified 11/16/2010 1:30 pm by Jason Byrnes | 2648 views | 5 replies |
tn228553
I am using the WA_SHA1Encryption format when inserting a record to my MySQL database via PHP and successfully encrypt a value on my WA DataAssist insert form per instructions I found on the forums.
My next question would be how do I decrypt them in the *Results.php page so that they can be viewed?
Please advise and thanks in advance!
SHA1 is a one way encryption format, it cannot be decrypted.
tn228553
Hey Jason! Good to "see" you. I just read that on another post...bummer. What/Is there a way to save the form value as encrypted in the database and then be able to decrypt it later? I am not super concerned about security but I need to make sure the value is not plain text either. What do you suggest?
here is a tutorial i found through google that may be helpful:
PHP-Encryption-Decryption-Using-the-MCrypt-Library-libmcrypt
tn228553
It's a little outside my realm. Is there nothing in the form of a sample I can use that has the WA insert and results pages using a simple encryp/decrypt such as MD5 or a custom key? I am not worried about long term storage of data, just interested in hiding the values from casual viewers perusing the database.
No this is not something we have a plugin to accomplish, you will need to do some hand coding to get this working.
