File Browser Issue
Thread begun 11/16/2010 8:56 am by Brett Atkin | Last modified 1/14/2011 1:29 pm by Jason Byrnes | 4477 views | 7 replies |
Brett Atkin
File Browser Issue
When ever I click the "Browse Server" button in the Link menu, it takes me to the folder will uploads go. I want to link the root of the site so that users can link to other pages within the site. I'm not sure what to change in the config.php file.
$WA_EditorLocalRoot = '/';
$WA_EditorRemoteRoot = '/';
$Config['UserFilesPath'] = 'images/uploads/';
$Config['UserFilesPath'] = $EditorAssumedRoot.$Config['UserFilesPath'];
Everything works fine with uploads and for adding an image (since the the File Browser is defaulting to to images/uploads folder.
Ideally, I would like the Link menu file browser to link to the root and and the Image menu file browser to link to the images/uploads folder.
If that isn't possible, I want to file browser to open up to the root of the site.
in the config.php page, the code that sets the file browser for files is:
$Config['FileTypesPath']['File'] = $Config['UserFilesPath'] . '' ;
you can change that to point to the root of the site instead of using the UserFilesPath
Brett Atkin
Father Pactona
Jason,
So I leave line 42 alone ($Config['UserFilesPath'] = 'images/uploads/';) but change line 137 from this:
to this:
$Config['FileTypesPath']['File'] = '' ;
Is that correct? I tried this and it didn't change anything.
Brett
rather than leave the setting blank:
set it to /
$Config['FileTypesPath']['File'] = '/' ;
Brett Atkin
Jason,
That isn't working. This is page I'm editing:
HTMLEditor\editor\filemanager\connectors\php
Here is what I think is the applicable code - Lines 41-52:
// Path to user files relative to the document root.
// Fill the following value it you prefer to specify the absolute path for the
// user files directory. Useful if you are using a virtual directory, symbolic
// link or alias. Examples: 'C:\\MySite\\userfiles\\' or '/root/mysite/userfiles/'.
// Attention: The above 'UserFilesPath' must point to the same directory.
$Config['UserFilesAbsolutePath'] = '' ;
if (isset($_SERVER['APPL_PHYSICAL_PATH'])) {
$Config['UserFilesAbsolutePath'] = str_replace("\\","/",$_SERVER['APPL_PHYSICAL_PATH']) . substr($Config['UserFilesPath'],1);
Lines 138-142:
// $Config['FileTypesPath']['File'] = $Config['UserFilesPath'] . '' ;
$Config['FileTypesAbsolutePath']['File']= ($Config['UserFilesAbsolutePath'] == '') ? '' : $Config['UserFilesAbsolutePath'] ;
$Config['QuickUploadPath']['File'] = $Config['UserFilesPath'] ;
$Config['QuickUploadAbsolutePath']['File']= $Config['UserFilesAbsolutePath'] ;
Brett
are you using the advanced file manager?
if so, you will need to edit the plugin/kfm/configuration.php file.
there should be a line that looks like this:
$kfm_userfiles_address = '../../../../images/uploads';
change it to:
$kfm_userfiles_address = '../../../../';
and there should be another line that looks like:
$kfm_userfiles_output = 'images/uploads/';
change that one to:
$kfm_userfiles_output = '/';
Brett Atkin
Jason,
We're getting there!
I'm able to browse from the root up...yahoo!!!
BUT...
When I select a file, it is adding an extra "/" to the beginning of the URL. For example:
<a href="//images/uploads/Florida Crown Results - Site Contest 2009.pdf" target="_self">
What now?
It also was restricting the PHP extension so I changed this line...
$kfm_banned_extensions = array('asp','cfm','cgi','ini','php3','php4','php5','phtm','pl','sh','shtm','shtml','ico');
...and it fixed it.
The comment on this line refers to uploads though - is that just an error in the comment text?
Thanks for the help. I appreciate it.
Brett
try removing the last slash from those two lines:
change it to:
$kfm_userfiles_address = '../../../..';
$kfm_userfiles_output = '';
