Radio Button validation
Thread begun 11/15/2010 2:20 pm by nickj | Last modified 11/22/2010 8:28 am by Jason Byrnes | 4596 views | 10 replies |
nickj
I've had no luck applying client valitation to radio buttons. Pleas look at the attached and point me in the right direction.
Also where is the documentation for applying client validation to radio buttons. THis is not obvious.
Nick
nickj
I went back and looked at the validation via the wizard and it has changed teh membership validation to the first name agian!
No predicting what willbe written!
when working with a radio group, the list of elements will have a main option for radio group:
WAATKRegistrationForm.memb_typ_us
and an indexed option for each element in the radio group:
WAATKRegistrationForm.memb_typ_us[0]
WAATKRegistrationForm.memb_typ_us[1]
the index at the end refers to specific radio buttons in the group. you should apply the validation to the main radio group:
In the code you provided, i do not see any validation applied to the radio group, only the "first_usr", "last_usr" and "email_usr" elements have validation applied.
nickj
Try this one please: BM_RegistrationWEBASSIST.php
Also where is the the radio button validation detailed in the documentation?
Nick
It looks like there is a bug with the radio group value lookup code, i have looged this in our bugbase
look for the following code:
else if (inputType == "radiogroup")  {
alert(formElement.length)
for (var x=0; x<formElement.length; x++) {
if (formElement[x].checked && formElement[x].value!="") {
value = formElement[x].value;
break;
and change it to:
if (formElement.length) {
break;
else if (formElement.checked)
value = formElement.value;
nickj
Starts to work but only for the first
Now works if you choose the first button but not the other two! I noticed there is are two entries for the group:
else if (inputType == "radio") {
break;
break;
OK, put that code back to what it used to be, I think I have the correct fix.
find the following line:
if (formElement.length && inputType.toLowerCase()!="radio" && inputType.toLowerCase()!="select") formElement=formElement[0];
and change it to:
I am logging this as a bug to corrected in a future version.
nickj
Sorry but the code is the same as produced but the wizard. Are you sure you entered the edited code?
Nick
sorry, the edited code should be:
if (formElement.length && inputType.toLowerCase()!="radiogroup" && inputType.toLowerCase()!="select") formElement=formElement[0];
nickj
Now we're talking val-i-dation!
Thanks!
Nick
