Digital goods download
Thread begun 11/15/2010 12:05 pm by davas56386677 | Last modified 12/06/2010 12:01 pm by massimo173451 | 4290 views | 8 replies |
davas56386677
Hello,
Avoiding customers to go through the complete checkout process for simple FREE DOWNLOADS, i changed a bit the code in results.php located in the \basic sub-directory as shown in results_php_in_basic_subdir.png (attached) under number "1". I check if the price is == 0 of the product to choose between a DOWNLOAD button or a LEARN MORE button (don't car about the french customization) as shown in the products_result_php.png (attached).
As I don't want to write a lot of code to skip the complete checkout process and jump from the results.php directly to view_downloads.php passing the product's associated down loadable filename contained in the ProductDigital field in the ps4_products table, I would appreciate any precise advice and help from the excellent tech support staff of WA to help me achieve an easy straightforward downloading of FREE FILES for my customer.
I join a ZIP file for better reading of the downsized PNG files
Many thx in advance for your kind support
Dan
to bypass the gateway if only free downloadable content is in the cart, edit the following line in the webassist/plugins/shopping_cart/process_transaction.php file:
// if in test mode, skip all checkout code
if ($WAGLOBAL_Test_Mode != true) {
if($WA_Store_Cart->GrandTotal() == 0$WAGLOBAL_Test_Mode true;
if (
massimo173451
Division by zero
Hi Jason, I get this error message why (I have set the product as price to zero for passing the checkout)?
Warning: Division by zero in /web/htdocs/www.tessyacconciature.it/home/webassist/plugins/shopping_cart/process_transaction.php on line 935
Massimo
davas56386677
Hello Massimo,
Did you apply the code modification as recommended by Jason:
To bypass the gateway if only free down loadable content is in the cart, edit the following line in the webassist/plugins/shopping_cart/process_transaction.php file:
Existing PHP Code at line 489:
NEW PHP Code at line 489:
if($WA_Store_Cart->GrandTotal() == 0) $WAGLOBAL_Test_Mode = true;
Try it, it works fine, even if your cart contains a mix of "zeroed" and "none zeroed" items.
Let me know if that solved your problem.
Daniel
massimo173451
Hello Daniel,
Thank you for your answer, but I have already applied the code variation on page the result is the same (see the image attached) if continue on confirm order (Conferma Ordine in italian) get paypal error the cart is empty!! Any further suggestion for solve this?
Massimo
davas56386677
Hi Massimo,
I just made new tests on my site using 2 items (one with 10 € and a second with 0 €). Everything ran without trouble. It passed PAYPAL and directed to the download page for the item of 0 €.
The error you get is issued by dividing "Price" with "TotalPrice" that contains ZERO (0). Look at the piece of code beneath that is on line 935 - 936 in the file /webassist/plugins/shopping_cart/process_transaction.php
if ((WA_eCart_FormatNumber($WA_Store_Cart->DisplayInfo("Price") - (($WA_Store_Cart->DisplayInfo("Price")/$WA_Store_Cart->TotalColumn("TotalPrice")) * $WA_Store_Cart->GetDiscounts()), false, 2) > 0)) {
Try to look backwards in your code for the values contained in "Price" and "TotalPrice". "TotalPrice" can only be ZERO (0) if "Price" also is ZERO (0). Just track backwards these two variables and you shall find where the mistake happens.
As I don't have access to the code of your site, you have to do the job.
Here my email: davas56@gmail.lu if you can't solve the matter by yourself.
Best regards
Daniel
massimo173451
Daniel,
I have sent you an email with page in attachment but receive the error from mail server (address not recognize)??
Massimo
davas56386677
Sorry Massimo,
Here is the right email: davas56@gmail.com. I misspelled it.
Try again sending the info and I'll have a look. OK !
Daniel
massimo173451
Thank you Daniel for your extra support, but as specified I am not expert in PHP language, the issue happens when in the cart is present only an item with value 0 (zero), and when put in the cart another item with different value > 0, the checkout is ok, but the PayPal price in USD not in Euro why??? Is eCart configurated correctly (&#8364; currency)? Any suggestion or support are appreciate.
Massimo
