Truncate Column on Data Assist Results Page
Thread begun 11/14/2010 7:26 pm by dlovas275157 | Last modified 11/22/2010 9:19 am by Jason Byrnes | 2497 views | 3 replies |
dlovas275157
Is there any recommendation on how to easily truncate text inside a column on the results page (generated by data assist)? Or maybe a CSS solution to shorten. I remember ADDT did this automatically.
The one column is always too long and makes the table extend way to far down the page.
See attached JPG.
Thanks for any advice.
-D.
you will need to edit the code used to out put that column using the php substr() function.
the code to output the column will look like this:
<?php echo $row_recordsetName["ColumnName"]; ?>
using the substr() function, you can set it to show only the first 50 characters:
<?php echo substr($row_recordsetName["ColumnName"], 050); ?>
see the following page for more details on the php substr() function:
function.substr.php
dlovas275157
Worked great. Thanks for the help.
D
you're welcome.
