Problem after theme change
Thread begun 11/13/2010 8:49 pm by Russell Collins | Last modified 11/16/2010 6:35 am by Jason Byrnes | 3450 views | 6 replies |
Russell CollinsBeta Tester
Im getting this error after a theme was customised.
Any ideas ?
Regards
Russ
Warning: fopen(../../Connections/installed.txt) [function.fopen]: failed to open stream: Permission denied in /home/brooklyn/public_html/webassist/themes/Default/images/installed.png on line 30
Warning: fread(): supplied argument is not a valid stream resource in /home/brooklyn/public_html/webassist/themes/Default/images/installed.png on line 31
Warning: fwrite(): supplied argument is not a valid stream resource in /home/brooklyn/public_html/webassist/themes/Default/images/installed.png on line 33
Warning: fclose(): supplied argument is not a valid stream resource in /home/brooklyn/public_html/webassist/themes/Default/images/installed.png on line 34
installed.png file damaged ?
I have tried opening the file installed.png file and it appears damaged.
I dl'ed another copy PS4 and I got the same result when opening it.
Any ideas ?
Russ
Did you delete any of the default theme?
It is important that the default theme stay intact.
Rename your existing webassist/themes/default folder to something else, then try replacing the webassist/themes/default folder with a fresh copy from the power store download.
Replaced entire folder
Hi Jason,
No, I didn't delete the default theme, I got rid of the problem though, I replaced the entire theme folder and all is fine again.
Russ
Ok, glad to hear it is working.
dave276887
PS4.01 Theme Problems
Hi I have the latest download and have store set up new/
However I cannot make changes to the theme, they do not stick, nor does the preview update.
I see that the previous person was able to upload a new themes folder, but for the life of me cannot find nor see this folder in my ps4 download. Though it is on my server in the webassist folder.
How do I get a new themes folder??
But finally got themes to work by changing the webassist folder file permissions to 755.
Dave
OK, glad to hear it is working.
