Data Assist2 Not Work -
Thread begun 11/13/2010 1:01 pm by paolo410517 | Last modified 11/17/2010 11:43 am by Jason Byrnes | 4731 views | 9 replies |
paolo410517
Greetings all, I recently purchased Super Suite, so I ask a little patience if my questions are of base type.
I'm using Super Suite - WebAssist, I created a sample database, and a simple table, to see how the wizard. I studied the site all phases of start-ups, but there is something that generates errors.
In MySQL DB, the table looks like this:
- idnome (integer 11)
- name (varchar 30)
from Wizard, I created the pages (by following the instructions of the WebAssist site):
- Results
- Search
- Detail
- Update
- Insert
- Delete
The records are listed by Results php file, but if I try to update a record I get the following error message:
Unknown column 'undefinedpaolo1undefined' in 'field list'
I have attached the file that the wizard has written and the database with its table.
I kindly ask you to give me some help. Thanks.
Dave BuchholzBeta Tester
Paolo,
Your issue is caused by line 56 on 04webassist_Update.php which reads:
$WA_columnTypesStr = "undefined";
This should read something like:
$WA_columnTypesStr = "',none,''"
for a text based field.
Try running the wizard again and if you still get the same results then I would suggest that you need a WA engineer to look at the issue as it may be something in your set-up that is causing it.
paolo410517
Hello Dave,
you have been very kind, thank you.
I made the change that I've written, now the script works correctly.
The Wizard of creation (I think it is very easy, considering that my experience comes from the now defunct estension Interakt !!!!!) I tried to give the variable NAME = Type the text, but the result was not taken into account at the end of Wizard.
I have tried to change the Type by the Update Wizard (after the creation I made double click on Update Record (04webassist) from tasck Dreamweaver) but to no avail! In fact, the script did not work.
This is the result of putting text in the Data Type of Step 2 in the editing stage of the Update Wizard
$ WA_where_columnTypesStr = "none, none, NULL";
This code produces the following error in the script:
Incorrect table name''
But now what do I do? because if you try again the Wizard continues to produce the code incorrectly? I think it's a problem of WebAssist! What should I do?
can you send a copy of the latest update page so I can examine the code.
paolo410517
To facilitate the display of all the wizard I created a PDF file, but since your board does not accept more than 293 KB, I had to split into multiple pages:
These attachments are the monitor screen for the Wizard
list_wizard_pag_1e2.zip
list_wizard_pag_3e4.zip
list_wizard_pag_5e6.zip
list_wizard_pag_7e8.zip
list_wizard_pag_9e10.zip
list_wizard_pag_11e12.zip
This zip file contains the list of products from the Wizard, with no changes
04webassist_lista_files.zip
This zip file contains the 04webassist_Update, as amended by clicking on the Dreamweaver Server Behaviors
04webassist_Update_Modificato.zip
I hope I was clear in the exposition of the problem, I await feedback.
Per facilitare la visualizzazione di tutto il wizard avevo creato un file PDF, ma dato che il vostro forum non accetta più di 293 KB, ho dovuto dividere in più pagine:
questi file allegati sono gli screen monitor relativi al Wizard
questo zip contiene la lista dei file prodotti dal Wizard, senza alcuna modifica
questo zip contiene il file 04webassist_Update, modificato facendo click su Comportamenti Server di Dreamweaver
Spero di essere stato chiaro nella esposizione del problema, attendo riscontro.
change this line:
$WA_table = "`04webassist`";
$WA_table = "04webassist";
paolo410517
Sorry but your answer is not very clear!
If I make the change, by manually editing the code, the script works. This
means that every time I need to edit the code produced by the Wizard?
the issue is caused by the naming convention used for your table.
table names should contain only letters, no numbers should be used in the tables name.
paolo410517
Valuable support,
I did the tests you requested:
1) I renamed the MySQL Name Table, removing the numbers
2) I reloaded the wizard WebAssist
3) I have attached the files to your PHP extension products from the MySQL DB
But, unfortunately, unsatisfactory ........
The Wizard continues to create the PHP code in a wrong way, because the variable
$ WA_columnTypesStr = "undefined";
continues to be produced undefined. Have you a correction Bug in your extension?
pregiatissimo supporto,
ho fatto le prove che avete richiesto:
1) ho rinominato la Tabella di MySQL, togliendo i numeri
2) ho caricato nuovamente il wizard di WebAssist
3) ho allegato i file in PHP prodotti dalla vostra estensione + il DB MySQL
Però, Purtroppo, insoddisfacente........
Il Wizard continua a creare il codice PHP in una maniera errata, infatti la variabile
continua ad essere prodotta undefined. Avete previsto una corezzione nella vostra Estensione?
