PS3 Search not working (entirely)
Thread begun 11/12/2010 10:56 am by terry164844 | Last modified 11/17/2010 8:08 am by Jason Byrnes | 4382 views | 8 replies |
terry164844
The PS3 Search (both the top nav and the dropdown search feature does not completely work properly.
Better put, it only remembers the last search that was completed.
Here's what I did:
1.) goto www.qlineshop.com
2.) click the search button on the home page without anything in the search box
3.) You should see all the products.
4.) enter in the search box 605, click search...the results does not change.
5.) It's like the search is stuck on the previous search and doesn't refresh.
Question: Is this resolved in the release 3.0.1 and I should apply this release? I wanted to ask first before I did.
Thanks for your help,
Terry
I'm not able to reproduce the problem. attached are screen shots after clicking the search button with nothing entered and then clicking the search button after entering 605 for the search term.
notice the second one says product 1 - 7 of 7
terry164844
yes...for me also I was not always able to duplicate the problem. I did however duplicate it a couple of times and more importantly the customer was able to.
After looking at the Product_Results.php page the sql gets pretty deep, so I'm inclined to to touch it until I'm completely familiar with how it works.
Tell me, is there (I don't see any) server variables that keep data where the search would pull from? It seems (when I can duplicate the problem) that the search is keeping the last known search criteria or sql statement.
I've been able to search on the 605 or something else and the search works, but when I search on something different it reverts to the 605 search results or the "all" products results
Thoughts?
the previous search is stored in a session variable named "WADbSearch1_Products_Results"
In reality to be able to troubleshoot the cause of the issue, we would need to know exact steps to reproduce the problem.
Does it happen when using a particular browser only?
a particular search term only?
If we can get specific steps for reproducing the problem, we will be able to find the cause.
terry164844
Jason,
Hi. I entered 605 in the search bar (not from the drop down) and I got a list of all the products in the store.
The URL that returned was this: (minus the quotes)
"http://qlineshop.com/store/Products_Results.php?pageNum_WADAProducts=2&totalRows_WADAProducts=26&Search=1&ProductCategoryID[]=5"
I don't know if this helps troubleshoot or not.
Let me know,
Terry
what browser are you using?
Are you clicking the search button or using the enter key?
in the main.dwt.php template, try changing the search form code:
<form id="searchForm" method="get"  action="../Products_Results.php" >
<input name="Search" type="submit" value="Search" id="Search" alt="Search" />
<input type="text" name="S_ProductName" id="S_ProductName" />
</form>
<input name="SearchSubmit" type="submit" value="Search" id="SearchSubmit" alt="SearchSubmit" />
<input name="Search" type="hidden" value="Search" id="Search" alt="Search" />
</form>
terry164844
Good question. I normally use chrome, however the client uses IE8.
As far as pressing enter or clicking the search button, more than likely I pressed the enter key. Honestly I don't remember.
Okay, please educate me. What would cause the difference in results? I know potentially a different key or form would be submitted depending on the focus
Also, is the code you provided just insuring that the code gets the "Search" value regardless of me pressing enter or clicking the search button. I've never seen that before and think it's pretty cool.
THANK YOU! I'll give it a try now.
Terry
terry164844
Jason,
I have been trying to test out the new code. I tried different browsers (IE8 & Chrome).
I was able to duplicate the problem :(
In IE8, was at the home page and typed in 605 in the search box and pressed enter.
This is the URL I got back:
"http://qlineshop.com/store/Products_Results.php?S_ProductName=605"
(without quotes)
but the results where not correct. It seems to have kept my last query or select which was the Kitchen Storage link on the left menu.
Very weird!
Thoughts?
PS...I am able to duplicate this. If you click on a left menu item and then search on something in the searchbox and press enter, it gives me the results from the previous left menu results. I try it again and I get the proper search results.
the issue is that some versions of IE do not send the submit button as part of the form submit in very small forms. The submit button is used as the trigger though.
the code change i gave you replaces the submit button named search with a hidden form element, this way the search will always trigger.
When i view source of your page, I do not see the change applied.
When making edits to the power store template, your power store files must be at the root of the Dreamweaver site for the changes to take effect on the child pages.
