Email Password - It's sending encrypted password
Thread begun 11/12/2010 9:44 am by PRIME | Last modified 11/29/2010 2:44 pm by Jason Byrnes | 1701 views | 5 replies |
PRIME
I have fallowed your tutorial point to point it's working but with one issue the password received in mail is encrypted password. I am using SecurityAssist 1.1.9.
you need to edit the Email Password server behavior.
go to Window -> Server Behaviors.
in the list of server behaviors, double click the Email Password server behavior.
On the last step of the email password server behavior wizard, you can set the email message. Right now, it is using the password column from the database, remove that, then click the plus button and select the NewPW Session variables that contains the unencrypted password.
PRIME
Thank you
Thank you it worked.
you're welcome.
robin.harrison368334
Don't see the NewPW session Variable?
I see what your saying in this postbut I don't seem to have the "NewPW" variable when I hit the "+" sign as you describe?
I have the database variables and session variables but no NewPW variable.
Does security assist create this variable in the wizard?
The first step to creating the Forgot password page is to add the set session value behavior to the page, in this step, the NewPW session variable is created. If you used a differant name, then use that session variable.
