replacing authorize.net code
Thread begun 11/11/2010 7:17 pm by msjj000 | Last modified 11/23/2010 7:06 am by Jason Byrnes | 5137 views | 13 replies |
msjj000Beta Tester
1111111111111111111
I'm not sure i follow what the question is, what code is it you are trying to replace?
msjj000Beta Tester
Hi James,
Apologies, finger problem. Two questions if I may?
1) I've seen how you have changes with PS4 over PS3 and moved the process off the confirm page. I've localized the product to my local GEO however items are not being added to my cart. Once clicked the the site moves to the cart page and the response "the cart is empty" is displayed. Are you able to assist please?
2) Just to confirm, can you allow a user a choice of either PayPal Standard and AuthNet on the checkout page?
Thanks, Mark.
hows the servers session management doing? use the session test from the following page:
showpost.php?p=23826&postcount=2
No, power store does not allow for both PayPal standard and authorize.net. only one or the other if you are using PowerStore 4
msjj000Beta Tester
Hi Jason,
Thanks. We'll stick to authorize.net for now.
Tested the session variables and it appeared to work. Eg, session changed from NULL to test and the session id did not change.
Where to from here?
Thanks, Mark.
_______________________
To Test you servers session management:
1) Click here to Set Session variables
The link above uses a URL variable to trigger setting a session variable
2) Click here to test session variables
This link does not contain the URL variable, so it will not set the session variable again, but the session variables value should not be changed.
Session Test = test
(When the page is first loaded, the session variable test will = NULL, when you click the first link, the session variable test will be set to test. Clicking the second link will only reload the page, the session variable test should still equal test, if it equals NULL, your server has a problem with session management.
Session ID = 6cdb41e4a96d542a6c784015768655ba
(NOTE: if sessions are working correctly, the session ID should not change.)
the true test is clicking the second link, does it still equal test after clicking the second link?
msjj000Beta Tester
Hi Jason,
Yes it does. Session code does not change regardless of the number of times either link is clicked. What should we do next?
Thanks, Mark.
can you post a link where I can see the issue and a copy of the add to cart page.
msjj000Beta Tester
Hi Jason,
Here you go file attached.
ridewerx.com/shop
I assume that once the install is complete that the files under the install directory remain on the host and are not use and any localization should be made to the other files.
Thanks, Mark.
The items are adding to the cart for me, i am not able to reproduce the error.
see attached screen shot of items in the cart.
Yes, the localization should not be done to the files in the install directory.
