Progress Bar causing javascript error
Thread begun 11/11/2010 2:34 pm by kata387222 | Last modified 11/15/2010 1:03 pm by Jason Byrnes | 1644 views | 3 replies |
kata387222
Trying to attach a progress bar to an existing form. When i do it comes up with this error message "While executing findServerBehaviours in Recordset.htm, a Javascript error occured." I am also getting these error when editing forms created by Form Builder using the edit buttons in the DW properties panel. I have followed instructions for installing and uninstalling deleting extensions, dat files etc to eliminate any installation issues - only have form building installed at the moment.
Tried again and the form does still work - the error has not affected the form??? Does anyone know why that error might be occuring?
Another issue I am having is to do with the style of progress. Big Spin works - but "Universal Email Progress 1" doesn't. Is this only for multiple uploads or something?
what is your version and build number of Dreamweaver?
Go to help -> About Dreamweaver. Click the about dialog once to scroll to the end, this will list the version and build number.
Can you also send a copy of one of the pages where you get this error in a zip file.
kata387222
CS5 Version 11.0 Build 4909. Zip File attached. I get the error when I go to live view and test. Thanks
one thing i see that may be contributing to the issue is using the name "user" as a table name in your database. This is a MySQL reserverd Word and should be avoided for table names.
