Paypal Transaction ID + Order table
Thread begun 11/11/2010 6:17 am by dan361748 | Last modified 11/12/2010 6:50 am by Jason Byrnes | 2525 views | 4 replies |
dan361748
Am I missing something or is there no corresponding Paypal Transaction ID saved by eCart in the orders table when an order is successfully processed? How do you tie the two together?
If you are using PayPal Direct Payments, go to the bindings panel, click the plus button and select eCart -> Checkout - > Local Checkout Response. From the gateway list select PayPal Direct Payments.
This will add a transaction ID binding that you can use in the store order summary behavior.
dan361748
Thanks Jason!
dan361748
Hi Jason - which page do I put this on? I can't see Local Checkout Response on my eCart, Checkout bindings. I see Local Checkout but no Local Checkout Response.
The store order summary behavior will be on the confirm page.
make sure you are on the bindings tab, see the screen shot attached.
