problem with meta base
Thread begun 11/11/2010 4:07 am by info269075 | Last modified 12/08/2010 6:58 am by Jason Byrnes | 7144 views | 14 replies |
info269075
HI
I can 't succced to make image resizer working on line. It works on local. I have a meta base, I think the problem comes from it.
the image cache folder is videos/image_cache, so on local, the plug in create a videos/image_cache/websitename/videos/crop/ systeme of folders to store the images. ( the meta base is on http//localhost/websitename/ )
But on the distant server it don't work anymore, the base dir is website.com and even if I put the videos folder to 777, Image resizer don't create the system of folders, maybe it tries to create it elsewhere, but where ??? I need to know to apply 777 autorisations
thanks for your help
can you send a copy of your page in a zip archive and link where i can see the issue to investigate the cause.
info269075
the zip and the adress
here is the page and here the url on the developement site:
presentation-journee-au-cirque,2.html
on your page, the cached image is inside of a repeat region:
do{
<div class="videoBox">
<a rel="shadowbox;width=<?php echo $row_rs_videos['width']; ?>;height=<?php echo $row_rs_videos['height']; ?>" title="<?php echo $row_rs_videos['titre']; ?>" href="videos/<?php echo $row_rs_videos['fichier']; ?>" class="transp">
if(TRUE){ // Begin Cached Resized Image: ImageCacheInstance_1289476015778
ob_start();
<img name="<?php echo $row_rs_videos['titre']; ?>" src="videos/<?php echo $row_rs_videos['vignette']; ?>" width="240" height="138" alt="<?php echo $row_rs_videos['titre']; ?>" class="vignette" />
echo(getCachedResizedImageHTML(ob_get_clean(), "videos/image_cache", "proportion", "", false));
} // End Cached Resized Image: ImageCacheInstance_1289476015778
</a>
<div class="clearfloat"> <p><?php echo $row_rs_videos['titre']; ?></p></div>
</div>
<?php } while($row_rs_videos = mysql_fetch_assoc($rs_videos));
mysql_free_result($rs_videos);
that is only shown if the rs_videos recordset returns a result.
when i view source of the page, i do not see the <div class="videoBox"> which indicates that the recordset is empty.
info269075
<div class="videoBox"> doesn't indicate that the recordset is empty, a the opposit it's there when it is not empty.
Everything things working fine on local server, it's only on the distant one that there is a problem. Maybe it comes from the
<base href="http://wrk.journee-au-cirque.com">
But anyway, Image resizer create a very long chain of folders to work, on local:
videos/image_cache/journeeocirque/crop/
where journeeoirque seem to comes from:
<base href="http://localhost/journeeocirque/" /> which the one on local server
If thinf IR try to create such path of folders on remote server, but don't succeed ( even when videos folder is on 777)
Is there a way to force IR to adopte my path
Right, what i am saying is that i dont see the <div class="videoBox"> in the source code which I should see if the recordset where not empty.
since i do not see the div, it indicates that the recordset is empty so the images are not being generated.
info269075
But I see the <div class="videoBox"> . And all the other informations from the recordset, only the picture doesn't appear
I do not see that if i visit your page at:
page_a.php
and view the source> In the source i am searching for the <div class="videoBox"> and it is not found.
Is there another page I should be looking at?
that is the page you sent in the zip file?
info269075
Ok, i undestand, this page is just empty without some variables, this is the url you have to look at
thanks
info269075
I doesn't come from the meta base, as i removed it, and it didn't changed anything.
