Checkbox value & Relational Table
Thread begun 11/10/2010 5:58 pm by dan361748 | Last modified 11/15/2010 1:07 pm by Jason Byrnes | 5665 views | 10 replies |
dan361748
Hi - I'm trying to send a checkbox value to a relational table. I think the relational part is working right, as it pre-selects my form. This is the second form on my page though. Anyway - can I send the checkbox value like this?
<input <?php if (!(strcmp($row_chapters['CHAP_ID'],WA_AB_returnPreSelectValue($WA_PreSelect_RelationalTable_1, $row_chapters['CHAP_ID'])))) {echo "checked=\"checked\"";} ?> name="CHAP_ID_<?php echo $RepeatSelectionCounter_1; ?>" type="checkbox" id="CHAP_ID_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo $row_chapters["CHAP_ID"]; ?>" />
tom92909Beta Tester
I did something similar to that very thing today...
I'm using DataAssist to Update the record...
$WA_connection = $dbconnect;
  $WA_table = "consultants";
  $WA_redirectURL = "";
  $WA_keepQueryString = false;
  $WA_indexField = "consultant_rec_id";
  $WA_fieldNamesStr = "fname|lname|title|emailaddress|password|status|group|phone_number";
  $WA_fieldValuesStr = "".((isset($_POST["fname"]))?$_POST["fname"]:"")  ."" . "|" . "".((isset($_POST["lname"]))?$_POST["lname"]:"")  ."" . "|" . "".((isset($_POST["title"]))?$_POST["title"]:"")  ."" . "|" . "".((isset($_POST["email_address"]))?$_POST["email_address"]:"")  ."" . "|" . "".((isset($_POST["password"]))?$_POST["password"]:"")  ."" . "|" . "".((isset($_POST["status"]))?$_POST["status"]:"")  ."" . "|" . "".((isset($_POST["group"]))?$_POST["group"]:"")  ."" . "|" . "".((isset($_POST["phone"]))?$_POST["phone"]:"")  ."";
dan361748
Thanks Tom
I think I need to use the relational table because the check boxes that contain the ID value are in a repeat selection, plus they need to pre-select when the form loads.
My main table is manuals
My option table is chapters
My relational table is map_mc
It's funny - the preselect portion works fine (the form loads with the current relational table data pre-selected), but when I submit my form the relational table behaviour just deletes the records with the main table ID (MANUAL_ID) rather than updating/adding them. It makes me the form is not passing along the option table id (CHAP_ID) and may have something to do with the way I have my checkbox values set up, but I'm stuck.
tom92909Beta Tester
I'm not sure, but I would recommend looking into using JOIN on your manuals & chapters tables on unique ID numbers.
Is that possible? Will that help? or am I missing what you're trying to accomplish?
dan361748
Thank you for your help Tom.
Doesn't the Manage Relational Table behaviour function handle the creation of the query and the JOIN?
I've attached my page - I hope that isn't presumptuous. Just so you know what I am looking at.
tom92909Beta Tester
LOL, I'll have to look into that Doh! I guess I'm still doing things the old way.
I'm manually creating my JOIN in my recordset.
SELECT clients.consultant_id, clients.client_rec_id, consultants.consultant_rec_id, consultants.fname, consultants.lname
FROM clients JOIN consultants ON consultants.consultant_rec_id = clients.consultant_id
WHERE client_rec_id = colname
The colname Variable is defined to receive the rec_id from a GET ( $_GET['id'] )
dan361748
Thanks Tom - yes I am talking about the Manage Relational Table behaviour.
The behaviour won't post my values. It will only delete the records that match the MANUAL_ID.
Any other suggestions?
dan361748
Tried a blank page - still no work
As a follow up to this I thought I would try the behaviour on a blank page and the problem is the same.
The behaviour deletes the corresponding records that match the MANUAL_ID key in the relational table. I'm convinced this has to do with no value being passed from the checkbox, however if I view the source the value appears correct. Here is my page:
<?php require_once('Connections/boomcms.php'); ?>
<?php require_once("WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
mysql_select_db($database_boomcms, $boomcms);
$query_manual = "SELECT * FROM manuals WHERE MANUAL_ID = 6";
$manual = mysql_query($query_manual, $boomcms) or die(mysql_error());
$row_manual = mysql_fetch_assoc($manual);
$totalRows_manual = mysql_num_rows($manual);
$query_chapters = "SELECT * FROM chapters";
$chapters = mysql_query($query_chapters, $boomcms) or die(mysql_error());
$row_chapters = mysql_fetch_assoc($chapters);
$totalRows_chapters = mysql_num_rows($chapters);?>
// WA DataAssist Manage Relational Table 1
if ($_SERVER["REQUEST_METHOD"] == "POST") // Trigger
$WA_arrayOrFieldList = 1;
$WA_joinLoopedField = "CHAP_ID";
$WA_loopedField = "WADA_RepeatID_CHAP_ID";
$WA_connection = $boomcms;
$WA_table = "map_mc";
$WA_masterKeyField = "MANUAL_ID";
$WA_masterKeyType = "none,none,NULL";
$WA_masterKeyValue = "".$row_manual['MANUAL_ID'] ."";
$WA_masterKeyComp = "=";
$WA_joinedKeyField = "CHAP_ID";
$WA_joinedKeyType = "none,none,NULL";
$WA_joinedKeyComp = "=";
$WA_fieldNamesStr = "MANUAL_ID|CHAP_ID";
$WA_columnTypesStr = "none,none,NULL|none,none,NULL";
$WA_appliedString = "";
$WA_appliedList = array();
$WA_valuesList = array();
$WA_connectionDB = $database_boomcms;
if ($WA_arrayOrFieldList == 0) {
$WA_loopedValues = $_POST[$WA_joinLoopedField];
for ($v=0; $v<sizeof($WA_loopedValues); $v++) {
$WA_fieldValues = "^MASTERID^" . "|" . "^JOINID^";
$WA_valuesList[] = array($WA_loopedValues[$v], $WA_fieldValues);
$WA_appliedString .= "^" . $WA_loopedValues[$v] . "^";
$WA_appliedList[] = $WA_loopedValues[$v];
else if ($WA_arrayOrFieldList == 1) {
$WA_mrtLoopCounter = 0;
while (WA_AB_checkLoopedFieldsExist(array($WA_loopedField), $WA_mrtLoopCounter)) {
if (WA_AB_checkLoopedFieldsNotBlank(array($WA_joinLoopedField), $WA_mrtLoopCounter) && WA_AB_getLoopedFieldValue($WA_loopedField, $WA_mrtLoopCounter) == WA_AB_getLoopedFieldValue($WA_joinLoopedField, $WA_mrtLoopCounter)) {
$WA_valuesList[] = array(WA_AB_getLoopedFieldValue($WA_loopedField, $WA_mrtLoopCounter), $WA_fieldValues);
$WA_appliedString .= "^" . WA_AB_getLoopedFieldValue($WA_loopedField, $WA_mrtLoopCounter) . "^";
$WA_appliedList[] = WA_AB_getLoopedFieldValue($WA_loopedField, $WA_mrtLoopCounter);
$WA_mrtLoopCounter++;
WA_AB_doManageRelationalTable($WA_valuesList, $WA_appliedString, $WA_appliedList, $WA_connection, $WA_table, $WA_masterKeyField, $WA_masterKeyType, $WA_masterKeyValue, $WA_masterKeyComp, $WA_joinedKeyField, $WA_joinedKeyType, $WA_joinedKeyComp, $WA_fieldNamesStr, $WA_columnTypesStr);
if ($WA_redirectURL != "") {
// WA DataAssist Pre-Select Relational Table 1
$WA_PreSelect_RelationalTable_1 = array();
$WhereObj = WA_AB_generateWhereClause(array($WA_masterKeyField), array($WA_masterKeyType), array($WA_masterKeyValue), array($WA_masterKeyComp));
$WA_Sql = "SELECT ".$WA_masterKeyField.", ".$WA_joinedKeyField." FROM ".$WA_table." WHERE ".$WhereObj->sqlWhereClause." ORDER BY ".$WA_joinedKeyField;
$WA_mrtJoinRS = mysql_query($WA_Sql, $WA_connection) or die(mysql_error());
if (mysql_num_rows($WA_mrtJoinRS) > 0) {
while ($row_WA_mrtJoinRS = mysql_fetch_assoc($WA_mrtJoinRS)) {
$WA_PreSelect_RelationalTable_1[] = $row_WA_mrtJoinRS[$WA_joinedKeyField];
// RepeatSelectionCounter_1 Initialization
$RepeatSelectionCounter_1 = 0;
$RepeatSelectionCounterBasedLooping_1 = false;
$RepeatSelectionCounter_1_Iterations = "1";
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
</head>
<body>
<form id="manualschapters" name="manualschapters" method="post" action="admin_Manuals_Grouping.php">
// RepeatSelectionCounter_1 Begin Loop
$RepeatSelectionCounter_1_IterationsRemaining = $RepeatSelectionCounter_1_Iterations;
while($RepeatSelectionCounter_1_IterationsRemaining--){
if($RepeatSelectionCounterBasedLooping_1 || $row_chapters){
<table border="0" cellspacing="0" cellpadding="0">
<?php do { ?>
<tr>
<td><?php echo $row_chapters['CHAP_TITLE']; ?></td>
<td><label>
<input type="hidden" name="WADA_RepeatID_CHAP_ID_<?php echo $RepeatSelectionCounter_1; ?>" id="WADA_RepeatID_CHAP_ID_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo $row_chapters["CHAP_ID"]; ?>" />
<input <?php if (!(strcmp($row_chapters["CHAP_ID"],WA_AB_returnPreSelectValue($WA_PreSelect_RelationalTable_1, $row_chapters["CHAP_ID"])))) {echo "checked=\"checked\"";} ?> <?php if (!(strcmp($row_chapters['CHAP_ID'],WA_AB_returnPreSelectValue($WA_PreSelect_RelationalTable_1, $row_chapters['CHAP_ID'])))) {echo "checked=\"checked\"";} ?> type="checkbox" id="CHAP_SELECT_<?php echo $RepeatSelectionCounter_1; ?>" name="CHAP_SELECT_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo $row_chapters['CHAP_ID']; ?>" />
</label></td>
</tr>
<?php } while ($row_chapters = mysql_fetch_assoc($chapters)); ?>
</table>
} // RepeatSelectionCounter_1 Begin Alternate Content
else{
<td>No records match your request.</td>
<?php } // RepeatSelectionCounter_1 End Alternate Content
if(!$RepeatSelectionCounterBasedLooping_1 && $RepeatSelectionCounter_1_IterationsRemaining != 0){
if(!$row_chapters && $RepeatSelectionCounter_1_Iterations == -1){$RepeatSelectionCounter_1_IterationsRemaining = 0;}
$RepeatSelectionCounter_1++;
} // RepeatSelectionCounter_1 End Loop
<input name="SUBMIT" type="submit" value="SUBMIT" />
</form>
</body>
</html>
mysql_free_result($manual);
mysql_free_result($chapters);
Any WA would be really appreciated. I can see a lot of uses for this behaviour, but am having trouble making it work. I can't use a list in this case as I intend on doing an order function on this table as well.
Try changing:
<?php } while ($row_chapters mysql_fetch_assoc($chapters)); ?>
<?php $RepeatSelectionCounter_1++; ?>
If that doesn't work, i'll start a private ticket to get more information from you.
dan361748
Hi Jason - thank you - I inserted the code and it still does not work. It just deletes the records that match the MANUAL_ID.
Please let me know if you are able to open a ticket. I've attached the page here.
