eCart 4 store Summary/Details in database issue
Thread begun 11/10/2010 12:08 pm by eric284736 | Last modified 11/10/2010 12:54 pm by Jason Byrnes | 2290 views | 3 replies |
eric284736
I am having an ongoing issue with the triggers for storing the data into the database.
This is a simple manual checkout and I am trying to have the Summary Store in database using the Button: Submit_Order when pressed.
Then have the store details use the trigger Any Form Post.
I set the triggers as I want click OK and save page. Open behavior and it has both behavior triggers set as Any Form Post.
Now I did have it working, but it seems to only work every few orders where it actually stores the info.
I have attached the confirm.asp page as a zip file.
thanks,
Eric
you have the store cart summary behavior set to redirect to the success page. this will happen before the store cart details behavior can execute, you should only set the store cart details behavior to have a redirect.
eric284736
Thanks Jason!
Does the trigger function matter whether it is any form post or button pressed?
thanks,
Eric
it should be set to button submit order pressed.
