Edit Theme Error 500
Thread begun 11/10/2010 12:06 pm by massimo173451 | Last modified 11/07/2011 7:24 am by Jason Byrnes | 5534 views | 11 replies |
massimo173451
Hi, when try to edit then publish theme I get the internal server error 500: Follow the log file captured on server, hope this will help you:
[Wed Nov 10 20:48:22 2010] [error] [client 95.250.32.124] PHP Warning: Illegal offset type in /web/htdocs/www.tessyacconciature.it/home/webassist/plugins/styler/filebrowse.php on line 19
[Wed Nov 10 20:48:22 2010] [error] [client 95.250.32.124] PHP Warning: Illegal offset type in isset or empty in /web/htdocs/www.tessyacconciature.it/home/webassist/plugins/styler/filebrowse.php on line 15
Regards:
Massimo
Dani Chankhour
Could you provide me with some steps to see if i can reproduce the issue on my end:
which themes you have selected and what kind of updates you made to the theme, and if you are getting this error with a specific theme or it happens when editing any of the themes.
Thanks.
massimo173451
The theme selected is Crazy, this scenario is reproduced when click a publish button. Jason has open a ticket for my different pbs.
Massimo
massimo173451
Any news or update for fix this issue??
Massimo
Dani Chankhour
I have opened a support ticket to further assist you with this issue:
Paul
Any update for this issue? I'm having the same problem
Dani Chankhour
What version of PowerStore are you using?
The fix to this issue should have been included in the latest version of Powerstore 4.5.
Paul
4.5...that I had downloaded when it came out. Is there a later version? If so, how do I update it?
Paul
Dani,
I did a clean wipe of the site today since I hadn't done any visual changes to it.
Downloaded the 4.5 files from the download section on the webasssit site and uploaded them. Was successful in installing and getting to the admin section.
I am having the same issue when I try and "edit theme" on the default theme. Here is the error:
PHP Warning: Illegal offset type in isset or empty in D:\home\acalamedical.com\wwwroot\webassist\plugins\styler\filebrowse.php on line 15
PHP Warning: Illegal offset type in D:\home\acalamedical.com\wwwroot\webassist\plugins\styler\filebrowse.php on line 19
Please advise.
