Transaction not completed Message
Thread begun 11/10/2010 11:11 am by elewis93815 | Last modified 11/19/2010 8:13 am by Jason Byrnes | 10433 views | 40 replies |
elewis93815
I'm trying to figure out why I'm getting a "Transaction not completed" message when I get to the check out screen. I would also appreciate some direction on:
1. Checkout validation page, what all should be server / client validated? credit cards numbers etc.
I've attached the files to this post.
Thanks!
Erick
add the following code to the checkout failure page:
if(!session_id()) session_start();
echo
"<p>Express Authorize: <br />"
     echo
"Full Request: ".(isset($_SESSION["ECO_Auth_Request"])?htmlentities($_SESSION["ECO_Auth_Request"]):"n/a")."<br />"
     echo
"Full Response: ".(isset($_SESSION["ECO_Auth_Result"])?htmlentities($_SESSION["ECO_Auth_Result"]):"n/a")."<br /></p>"
     echo
"<p>Express Process: <br />"
     echo
"Full Request: ".(isset($_SESSION["ECO_Process_Request"])?htmlentities($_SESSION["ECO_Process_Request"]):"n/a")."<br />"
     echo
"Full Response: ".(isset($_SESSION["ECO_Process_Result"])?htmlentities($_SESSION["ECO_Process_Result"]):"n/a")."<br /></p>"
This will write the full request and full response to the screen to help us troubleshoot.
NOTE: The full request and full response will contain sensitive information that should be removed before posting here.
2) the main difference between client and server validation, is that client validation can be disabled if the customer turns JavaScript off.
I always recommend using server validation.
elewis93815
Thank you Jason,
I pasted the above code at the end of the php portion of the code. This is what it comes back with, Hope this helps:
Express Authorize:
Full Request: n/a
Full Response: n/a
Express Process:
Full Request: n/a
Full Response: n/a
Transaction Not Completed
We're sorry
Your transaction could not be completed.
I apologize, i gave you the wrong code chunk for authorize.net, the code to add is:
echo
"<p>Auth Net: <br />"
     echo
"Full Request: ".(isset($_SESSION['WAAuthNet_postedValues'])?htmlentities($_SESSION['WAAuthNet_postedValues']):"n/a")."<br />"
     echo
"Full Response: ".(isset($_SESSION['WAAuthNet'])?htmlentities($_SESSION['WAAuthNet']):"n/a")."<br /></p>"
elewis93815
Hello Jason,
This is the results that we get when we attempt to check out:
Auth Net:
Full Request: _version=3.1&x_invoice_num=t2jrtfqk68011hb2u4dct3fq65&x_test_request=TRUE&x_method=CC&x_type=AUTH_CAPTURE&x_relay_response=FALSE&x_delim_data=TRUE&x_delim_char=::&x_customer_ip=76.17.154.83&x_amount=56.70&x_description=6 Paris Hilton (7), 6 Strawberries and Cream (5), 6 Mint Chocolate Chip (8), 12 Baby Mocha (13)&x_line_item=7<|>Paris Hilton<|>Vanilla cupcake with vanilla simple buttercream covered in hot pink sprinkles<|>6<|>1.95<|>YES&x_line_item=5<|>Strawberries and Cream<|>Vanilla cupcake stuffed with fresh strawberries topped with vanilla frosting and fresh strawberries<|>6<|>2.5<|>YES&x_line_item=8<|>Mint Chocolate Chip<|>Tiny chocolate chips floating in yummy peppermint frosting on top of a dark chocolate cupcake makes your mouth water and freshens your breath<|>6<|>2.5<|>YES&x_line_item=13<|>Baby Mocha<|>Coffee meets chocolate Frosting made with real ground espresso on top of a dark chocolate cupcake. Drizzled with chocolate just for good measure.<|>12<|>1.25<|>YES&x_card_num=&x_exp_date=&x_card_code=&x_email_customer=TRUE&x_tax_exempt=FALSE&x_first_name=&x_last_name=&x_address=&x_city=&x_state=&x_zip=&x_phone=&x_fax=&x_email=&x_country=&x_ship_to_first_name=&x_ship_to_last_name=&x_ship_to_address=&x_ship_to_city=&x_ship_to_state=&x_ship_to_zip=&x_ship_to_country=&x_ship_to_phone=&x_ship_to_fax=&x_currency_code=USD&x_recurring_billing=NO
Full Response: 3::1::103::(TESTMODE) This transaction cannot be accepted.::000000::P::0::::::56.70::CC::auth_capture::::::::::::::::::::::::::::::::::::::::::::::::::::34E4F0425C3BD36C86DBD77A33578862::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::
We're sorry
That error message means that authorize.net is not excepting the transaction key or the login. From the code you sent, i cannot see an problem with those values, they appear to be correct. you should double check them, if you dont see a problem, contact authorize.net to see why they are not being excepted.
elewis93815
This post has been deleted.
elewis93815
New Errors look like something with Universal Email
Hi Jason,
We fixed a bunch of incorrect API and login info, however this is the new error that we're getting: Warning: Missing argument 6 for WAUE_Definition(), called in /home/content/97/6933397/html/WA_Universal_Email/WAUE_confirm_1.php on line 15 and defined in /home/content/97/6933397/html/WA_Universal_Email/mail_PHP.php on line 69
Warning: Cannot modify header information - headers already sent by (output started at /home/content/97/6933397/html/WA_Universal_Email/mail_PHP.php:69) in /home/content/97/6933397/html/confirm.php on line 325
Erick
On the confirm page, double click the universal email server behavior and make sure that a Character set is selected, then click ok.
elewis93815
Thanks!!! that looks like that fixed the problem, I got to the order success check out page. I used the UTF-8 character set.
Thanks again!
Jackie
