UE 4.01 - Missing Sender field - $MailFrom
Thread begun 11/10/2010 9:04 am by tom92909 | Last modified 11/11/2010 8:41 am by Jason Byrnes | 3938 views | 6 replies |
tom92909Beta Tester
Howdy folks! :)
I'm having some trouble with getting the proper data to display in a UE 4.01 mailing. Everything works fine, EXCEPT the defined $MailFrom isn't working.
A special note...
Last week I upgraded to CSS Form Builder 2. I uninstalled UE4.01, CSS Form Builder v1.02, and HTML Editor v2.02 (there might have been something else, but I think those were the only extensions that I uninstalled). I then installed the new CSS Form Builder v2 and then realized it wasn't really what I wanted to use all the time, but only in specific situations, so I removed it and then reverted back to the previous installations. I also killed the Winfilecache file in the Configuration directory and killed the SiteCache directory. This action seemed to get things back in working order.
try leaving the from display blank and only entering the from email address.
tom92909Beta Tester
Just to clarify....
Line 9 should be more like this?
$MailFrom = "";
I'm asking for the clarification because by removing it, it leaves the same result, but perhaps scrubs the sender domain even more...
tom92909Beta Tester
Ok...
I think I've diagnosed the issue...
I have an ALIAS email address that I'm using on my Linux server as my $MailFrom defined sender address.
This is a problem. If I use a real (physical) email account on the server, then it works perfectly...
interesting, sounds like the gmail system is trying to do a lookup on the email address.
perhaps try adding the aliased email to your gmail contacts?
Is there a specific reason to use the aliased email over the real email address?
maybe use the real email as the From address but use the aliased email as the reply to address?
tom92909Beta Tester
Right. I'm using a real email address now and not a forwarding (alias) and it works perfectly now.
Thanks.
OK, glad to hear it is working.
