How to display Authorize.net failure response on checkout_failure page
Thread begun 11/09/2010 2:40 pm by SaladoGuy | Last modified 11/11/2010 1:48 pm by Dave Buchholz | 6112 views | 14 replies |
SaladoGuyBeta Tester
Hello,
The checkout wizard that generates all the checkout pages makes two final pages (along with all the others) checkout_success.php and checkout_failure.php.
Initially the checkout_failure page just says:
"Transaction Not Completed
We're sorry
Your transaction could not be completed. "
I want to add more detail and have it show the reason the card was declined, if possible.
By searching in the forms I found this thread: showthread.php?t=649&highlight=authorize.net+response
That gives me an idea but I still am not quite sure how to implement this...
In DreamWeaver I see that if I have the checkout_failure page up, there's not really anything in the Bindings panel that I can use, but if I open confirm.php, Bindings contains
something called "Local Checkout Response (Authorize.net)".
What I tried doing is posting all of those as hidden fields in the form, and then echoing the post on the checkout_failure page - but that's not working.
The form code on the confirm.php page looks like this:
<input name="rcode" type="hidden" id="rcode" value="<?php echo(AuthNet_Result("Response Code")) ?>" />
<input name="rsubcode" type="hidden" id="rsubcode" value="<?php echo(AuthNet_Result("Response Subcode")) ?>" />
<input name="rreasoncode" type="hidden" id="rreasoncode" value="<?php echo(AuthNet_Result("Response Reason Code")) ?>" />
<input name="rreasontext" type="hidden" id="rreasontext" value="<?php echo(AuthNet_Result("Response Reason Text")) ?>" />
(that's all just above the buttons for the checkout form)
and the post echo on the checkout_failure page looks like this:
<?php echo $_POST["rcode"]; ?>&nbsp;<?php echo $_POST["rsubcode"]; ?>&nbsp;<?php echo $_POST["rreasoncode"]; ?>&nbsp;<?php echo $_POST["rreasontext"]; ?>
Nothing is actually displayed, so either I'm not handling the echo right, or I'm it's not really getting into the hidden field (which seems more likely ... since the response data can't exist until after the form is posted ... but then how are you suppose to capture the data?).
(BTW ... we do NOT have the AVS service enabled at Authorize.net - but we should still be able to see and print out the reasons the card was declined, right? Or does the x_relay_response only work with AVS?)
I echoed all the session variables on the failure page and i see this (along with the rest):
["WAAuthNet"]=> string(455) "2::1::2::This transaction has been declined.::::U::3281283316::c984cdf88677653a2aea::
What is the proper way to do this? Should I forget the hidden fields and the _POST echo, and parse & echo out of the session variable array instead?
Also I don't quite understand: should x_test_request be set to TRUE or FALSE while I'm doing this - or does it not matter?
BTW I did change x_relay_response to "TRUE" in confirm.php.
Dave BuchholzBeta Tester
This is how I do it on the Cotswold Site
We're sorry, your transaction could not be completed for the following reason:<br /> <span><?php echo(AuthNet_Result("Response Reason Text")) ?>
Originally Said By: Dave Buchholz
Hi Dave,
I tried that code in checkout_failure.php and it still didn't work ... I must be missing something. Is there an include I need to put at the top of the checkout_failure page in order for it to access this information?
In other words how do I make sure php has access to the AuthNet_Result function and how do I make sure that it's initialized properly (in the sense of getting the authnet response assigned to the variables).
I'm brand new to all of this so please assume that I don't know anything :-)
I have x_test_request set to FALSE and x_relay_response set to TRUE in confirm.php. Is there anything else I need to set? Is there anything I need to configure in my authorize.net account settings?
I'm using the test card number 4222222222222 to make it fail.
have you got this include on your page ?
require_once("WA_eCart/Adv_CO_Scripts/AuthNet_PHP.php");
tom92909Beta Tester
The following defines Authorize.net FULL TEXT responses...
Primer: The first digit: "**1**":1:1:This transaction has been approved
1 = approved
2 = declined
3 = error
4 = under review
Those are the only possible response codes that you will receive from Authorize.net
Originally Said By: tom92909
1 = approved
2 = declined
3 = error
4 = under review
OK Tom, I appreciate that. Still, my problem is I don't know how to "get" those values so that I can do something with them. Am I supposed to extract them out of the session variable WAAuthNet ?
tom92909Beta Tester
In your confirm page, you'll want to store these to responses from Authorize.net...
"".(AuthNet_Result("Response Reason Text")) .""
"".(AuthNet_Result("Full Response")) .""
It's been awhile since I did this, but I want to say that the "".(AuthNet_Result("Full Response")) ."" will general a number and the FIRST digit will provide you with what you're looking for...
1 = approved
2 = declined
3 = error
4 = under review
tom92909Beta Tester
I just checked two of my client sites... I found (6) different results.
"".(AuthNet_Result("Response Reason Text")) ."" will provide the following possible outputs.
This transaction has been approved.
The transaction resulted in an AVS mismatch. The address provided does not
A valid amount is required.
Credit card number is required.
The card code is invalid.
I'm sorry but I'm such a newbie that I don't know what exactly "store these to responses " means in precise technical terms.
Are you saying that I should post these as the value of a hidden field to the next page?
Something like this?:
<input name="fullresponse" type="hidden" id="fullresponse" value="<?php echo(AuthNet_Result("Full Response")) ?>" />
This is similar to what I had before: in confirm.php I put a bunch of these things in hidden fields:
And then on the checkout_failed page I tried to echo the $_POST but it did not work.
I'm probably misunderstanding something or missing a simple step ... can you enlighten me?
Thanks for all the help.
tom92909Beta Tester
In addition to eCart, I also developed an Administrative backend using DataAssist to store all of the sales history into a MySQL table.
I have (2) tables that I write to (storing the data) when a transaction occurs...
$WA_table = "orders";
  $WA_redirectURL = "";
  $WA_indexField = "OrderID";
  $WA_fieldNamesStr = "OrderReferenceID|OrderUserID|OrderShipping|OrderTotal|OrderDate|OrderStatus|ppTransID";
  $WA_table = "orderdetails";
  $WA_indexField = "DetailOrderID";
  $WA_fieldNamesStr = "DetailOrderID|DetailProductID|DetailProductName|DetailProductDesc|DetailQuantity|DetailPrice|DetailOption1";
Having said that, this development took me probably 3 months to finish the 1st time I implemented an eCart web application. I too was really new to all of this and many of the concepts were initially hard for me to grasp.
