DA SQL Query Problem
Thread begun 11/09/2010 6:23 am by rick178787 | Last modified 11/09/2010 12:42 pm by Jason Byrnes | 1765 views | 3 replies |
rick178787
This is the DW query generated by WA as a set of pages. Note_Details.php:
SELECT NoteID, NoteSubjID, NoteSourceFK, Note_AuthorSited_FK, NoteKeywords, NoteTxt, NotePages, NoteDate, NoteMod
FROM Note
WHERE NoteID = ParamNoteID OR ( -1= ParamNoteID2 AND NoteID= ParamSessionNoteID)
the MySQL DB is fully relational, so I wanted to flesh out the details page with information from other tables referenced by the _FK (foreign key) selects so I added some joins:
SELECT Note.NoteID,
Note.NoteSubjID,
Note.NoteSourceFK,
Note.Note_AuthorSited_FK,
Note.NoteKeywords,
Note.NoteTxt,
Note.NotePages,
Note.NoteDate,
Note.NoteMod,
Subject.Subject_TEXT,
Source.Source_Title,
Author.AuthorLN,
Author.AuthorMN,
Author.AuthorFN
FROM Note INNER JOIN Subject ON Note.NoteSubjID = Subject.Subject_ID
INNER JOIN Source ON Note.NoteSourceFK = Source.SourceID
INNER JOIN Author ON Note.Note_AuthorSited_FK = Author.AuthorID
In production, this new query fails and returns No Record. If I strip out all between ParamNote ID > ParamSessionNoteID) and insert an actual record number it still returns No Record.
HOWEVER, the second query works at the database with a record number instead of ParamNote ID > ParamSessionNoteID).
I don't understand what's wrong here.
most likely the issue is with the join.
when using the INNER JOIN type, there mu st be a match on both sides of the join to return a result. If one of the tables does not a record in it to satisfy the join, no result will be returned.
Double check to make sure that there is data to satisfy the join in all of the tables being joined.
rick178787
That's it!
Well done. Guess I'll need to rethink that.
great, glad to hear that sorted it.
