Cms
Thread begun 11/09/2010 2:28 am by alistair316863 | Last modified 11/10/2010 6:42 am by Jason Byrnes | 2787 views | 3 replies |
alistair316863
Cms
Just so I can get it clear in my head, If I create my site locally and test locally but use Dynamic Connections when i upload my files to my live site will everything that i did locally but done on my live site including all correct image paths etc and will this also work with power gallery doing the same thing regards Alistair
No, Dynamic connections has nothing to do with the data that is in the database.
Dynamic connections can be used to tell the site which mysql server to connect to based on the URL or other parameters.
alistair316863
Ok thanks don't really get the use of it then, just for future development something that will do what I thought this would do would be great.
There are a number of different uses for dynamic connections.
First and foremost is to solve the issue of maintaining a local and remote checkout file when doing local development. Dynamic connections allows you to set up one connection file with both local and remote database details, and it will use the correct ones based on URL.
It also offers the ability to set the connection character set which will help solve issues with storing and retrieving data that contains accented characters.
Another user would be a multi lingual site, you could crate two separate databases, one for English, another for Spanish content. have the user select their language and store that in a session variable. using the session variable, you could determine which database to connect to.
