Facebook Link
Thread begun 11/08/2010 2:07 pm by KiddaMan | Last modified 11/17/2010 8:03 am by KiddaMan | 5861 views | 15 replies |
KiddaMan
Facebook Link
Hello,
Where and how would I insert a facebook icon (with link) for the home page using Powerstore 4 ??
Dani Chankhour
If you are referring the like button, you can read this page for more information:
like
KiddaMan
Sorry, my first post was a little vague. I was referring as to where I would have to insert the FB image in to the home page... the Index.php, so that the facebook image shows up in the footer section, then I can link it to my facebook page.
When I open up the index.php file, I can't seem to locate any of the home(index) page div's
another way of asking may be, how can I insert a picture into the index or home page footer section to the right of the FAQ link ?
Dani Chankhour
to modify the index page you will need to open the index template which is located under:
webassist/themes/the theme/templates/index.dwt.php
and you will see there is footer div where you can make your changes.
KiddaMan
That's what I was looking for !
Where should I insert the google analytics code for tracking hits ?
Thanks again for the help
Dani Chankhour
In PowerStore v4, under the settings page there is a Google Setting section that you could paste the Google analytic code.
KiddaMan
Wow
Thats was a bad miss on my part !
Thanks !
KiddaMan
Hello Dani,
I went into "webassist/themes/the theme/templates/index.dwt.php" and inserted the facebook code for the like button; however, it doesent insert the button directly to the right of the FAQ link (see attachments, both snap shot of homepage and code), It puts the button below it which makes the footer section larger(more height)
How can i put the button or other pic right next to the FAQ ?
neilo
Hi there,
The footer is an include which you would need to modify or add to using the PoweStore's cms. You would need to look for and edit the Main Template Footer after clicking to edit the content in the Admin section.
Add your code in source view BEFORE the existing closing </p> tag.
KiddaMan
Amazing !
Testing now.
