Edit Menu and Submenu
Thread begun 11/06/2010 10:05 am by massimo173451 | Last modified 11/09/2010 7:20 am by Jason Byrnes | 2962 views | 5 replies |
massimo173451
I am using PS and need to edit, or translate it in Italian language, the existent menu and submenu (eg Home, Products, Support, Contact Us etc). How I can accomplish this ??? And why is not possible edit any pages in DW instead use PCMS (is available a PDF guide about how to use PCMS) ??
Regards:
Massimo
If this is power store 4, edit the webassist/plugins/main_menu/menu.php file to change the top level menu items.
massimo173451
But if I need to add a customize menu (using integrated CMS in PS4) how I can insert it (no documentation available for this) ??
Massimo
I'm not quite sure what you mean, can you send a screen shot demonstrating the issue?
massimo173451
Sorry Jason for my bad english, I need insert e menu (submenu is already there) between PRODOTTI (Products) -> new menu here <- CONTATTACI (Contact Us) and then change the contents in the middle page where no image is present (AgeRegharge) then Sample Product with its image. I suppose this is obtained using PCMS, when enter as administrator (no edit icon is visible on these objects when enter as administrator, but I don't know this product no guide or documentation are available on my download page), May you help me to make this step?
Massimo
The menu is not edited through the CMS, you need to edit the code on the webassist/plugins/main_menu/menu.php file directly to change the top level menu items.
the products that are displayed on the index page are the featured product and top selling product. Right now it is showing dummy data, this will change once you add products to the product catalog.
When adding a product in the Powerstore Admin section, there is a button "Feature ON Home Page" to control which item is featured.
until you get some orders, the featured item will also be the most popular item. once some orders are placed, the most popular will be the item that is ordered the most.
