Error when open CMS
Thread begun 11/06/2010 9:05 am by massimo173451 | Last modified 11/09/2010 9:27 am by Jason Byrnes | 4004 views | 7 replies |
massimo173451
Error when open CMS
I have installed with success PowerCMS with PS 4, but when log in CMS iget on top page following message and no Content available for edit, what's wrong???
Parse error: syntax error, unexpected T_STRING in /web/htdocs/xxxxxxxxxxxxxx/home/PowerCMS/WA_Globals/WA_Globals.php(58) : eval()'d code on line 1
Regards:
Massimo
edit line 58 of the WA_Globals/WA_Globals.php
eval("\$WAGLOBAL_".$value[$x][4]."='".replaceTokens($value[$x][1],$tabs)."';");
eval("\$WAGLOBAL_".$value[$x][4]."='".addslashes(replaceTokens($value[$x][1],$tabs))."';");
massimo173451
Thanks Jason, the first issue is solved, but the Contents are not available for edit (is possible only add the Content but nothing is showed, the web site has the pages (generated by PS4 installation)) why?
Massimo
I'm sorry, I dont follow what you mean, can you send a screen shot demonstrating the issue?
massimo173451
Jason, I have attached the image for show the issue, no Content available when enter as administrator in my web site why?
Massimo
When you first install Power CMS, there is no content in the database, you need to add the content by clicking the plus button next to content.
massimo173451
Thanks Jason as always for you answer.
Massimo
You're welcome.
