batch update on pricing or another field
Thread begun 11/06/2010 7:46 am by terry164844 | Last modified 11/08/2010 4:40 pm by terry164844 | 2925 views | 4 replies |
terry164844
I have a store with 100's (504 to be exact) products. One of the issues that just came up was that the pricing is completely wrong on 85% of the products.
Is there a way to build a batch edit so that I can get a list of all the products and update a field or fields and it update the skus?
This would be very helpful so we don't have to go into every single product and update the pricing.
What are your thoughts?
Terry
No, batch updating or inserting is not supported in power store.
terry164844
Does WA have any solutions outside Powerstore?
CraigRBeta Tester
if you are comfortable with mysql and if you have dataassist, then you could consider using the update multiple records server behavior
terry164844
I found a solution. I don't have DataAssist so I had to find an alternative.
10.html
Works perfectly. I suspect that DataAssist would be easier to implement and have better structure for the code and such, but it works and I can move on down the road.
Terry
