Data Assist and Templates
Thread began 11/05/2010 8:32 pm by vonniea383657 | Last modified 11/08/2010 7:03 am by Jason Byrnes | 732 views | 1 replies |
vonniea383657
I worked through the getting started guide yesterday without using a template and all was fine. Today I was trying to use a .dwt template and none of the WADApage___ divs are working. They appear in the <body>, but they aren't created in the <style> section of the code and therefore don't work.
Where are they supposed to be?
Thank you,
~Giovonnae
On the first step of the data assist wizard, where you select the template, you also select the editable region that will be used.
