Insert/Update DateTime Record with now()
Thread began 11/05/2010 1:35 pm by sorenson3241 | Last modified 11/06/2010 8:11 am by sorenson3241 | 1794 views | 5 replies |
sorenson3241
I am working on an employee time card website page. In DataAssist I am using 'Update Record Wizard'.
When an employee clicks on a Clock In page. The page list what their daily assignments are.
They then click a submit button and it trigger the 'Insert Record' behavior. This behavior inserts the records creating an ID and adding the employee name via a URL parameter. I also want to insert 'now()' into a clockin field.
In the insert record wizard if I set the 'Value' (page 2) of the checkin field to 2010-11-5 it inserts it with no problems. If I set the the 'Value' of the checkin field to now() or current_date() it puts 0000-00-00 into the datetime field.
I want to repeat this process when they checkout using 'Update Record' wizard.
How do I configure DataAssist to insert the current_date() or now()???
Bob
Dave BuchholzBeta Tester
Bob,
make the field an integer field I usually use int(11) like so in my set-up sql file
`tstampinsert` int(11) unsigned DEFAULT NULL COMMENT 'Insert Timestamp use <?php echo time(); ?> in a hidden field in your form',
and as the comment says set up a hidden field with the value as
and insert that field when using the DA wizard
sorenson3241
David,
Thank you for the reply. I now have "1289008548" in the 'checkin' field.
I now need to display a column of all the employee 'checkin' times in repeating recordset region formated as a regular date '2010-11-05 12:58:33' not the 10 digit integer. How do I do the conversion or reformatting.
I also need to do the conversion for a column of 'checkout' date/times.
Finally, I need to substract the 'checkout' time from the 'checkin' time and get the elapsed time worked.
Thank you again for any help.
Bob Sorenson
this_is_me
timestamp?
a mysql - timestamp field (length=14) would do this automatically on changing or inserting new data.
Bob,
see function.date.php for details on how to format unix timestamps and there is a good example on how to calculate time differences here b-16.html
sorenson3241
To member 'this_is_me'. I have two timedate fields. Checkin and Checkout. Mysql will NOT allow me to have two timestamps. It would make it much easier if it did.
To member Dave. Thank you for the help. I just wish there was an easier way to handle imputting multiple date fields.
To Webassist. Add to DataAssist the ability to add a Mysql Function Now() or current_date() as a value in a date field.
Best,
Bob
