Can Not Update Product Options because ...
Thread begun 11/05/2010 10:55 am by terry164844 | Last modified 11/07/2010 12:17 pm by Dani Chankhour | 2070 views | 3 replies |
terry164844
For a product there are options. The option's description contain " marks for inches.
For example:
Values:
Zinc, 200mm(8"): Edit
Zinc, 250mm (10"): Edit | Delete
Zinc, 300 mm(12"): Edit | Delete
Zinc, 350 mm(14"): Edit | Delete
Zinc, 400 mm(16"): Edit | Delete
Zinc, 4500 mm(18"): Edit | Delete
Zinc, 500 mm(20"): Edit | Delete
Zinc, 550 mm(22"): Edit | Delete
Zinc, 600 mm(24"): Edit | Delete
Zinc, 650 mm(26"): Edit | Delete
When I try to edit the option I can not. I get a javascript erorr at the bottom of the page that says:
Line: 272
Char: 41
Error: Unterminated string constant
Code: 0
URL: options_Add.php?ProductID=45
When I take out the " in the options everything works fine.
Because I had this problem before on the product update page I added the following to the options_add.php page
ini_set('magic_quotes_gpc','on');
however, that didn't help...
Any thoughts? My first thought was not to put in the " for inches however it's important to the customer.
Terry
Dani Chankhour
It looks like you are using PowerStore Version 3. have you upgraded to the latest dot release which include a fix to that issue?
terry164844
Thank you Dani
I did download the 3.0.1 update but didn't fully update it because I didn't want to overwrite all the little changes I've made.
Word to self - need to implement a change management procedure for next site.
I did however update the options_add.php file and it fixed the problem.
Thanks a million.
Terry
Dani Chankhour
I'm glad i was able to help.
