Site Import No Wizard
Thread begun 11/04/2010 11:11 pm by shopper416550 | Last modified 11/05/2010 10:38 am by Dani Chankhour | 1803 views | 1 replies |
shopper416550
I have DW CS5 and Site Import 3. I have imported two or three websites, but now when I go to the website tools bar, processing drop down and click 'go' nothing happens. The import wizard is supposed to pop up and ask for the url, etc. I've read many posts with a similar problem, so I tried to find the OSX cache but apparently it is in a different place on DW CS5. I uninstalled and reinstalled twice. I cleared the cache (library/caches) but I think that is OSX cache and not DW. Please help an obvious newbie.
Dani Chankhour
You Cache file should be located under this location:
--Hard disk: Users: <Your User Name>: Library: Application Support: Adobe: Dreamweaver CS5: en_US: Configuration
I recommend that you delete the configuration folder, launch the extension manager and remove all other extensions and then re-install Site Import and launch Dreamweaver and check to see if you are still seeing the issue.
